I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options to connect to internet this way but cant and i cant set up a network.
  • 17 Answers
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Posted on Aug 21, 2008
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
Wireless Network Adapter -------------------------------------------------------------------------------- I have a Compaq Pressario A900 which was running Windows Vista with wireless networking...
First things first go to start/controlpanel/system/devicemanager and select network adapters if there is a yellow light thing that means no drivers were installed go to compaq and download the for the version of windows you have
second go to control panel and select network connections and where you see the wireless card icon click the right mouse button and enable it
hope it helps dont forget to rate ty
Jan 07, 2011 | Compaq Presario Notebook
Won't stay connected to internet
that might take an uninstall and reinstall of either the ethernet drivers, or the operating system. I haven't heard that, but I have had machines that aren't as reliable in the wireless as they could be. it's possible that something in the workings of it has gone haywire, but it sounds like an OS issue.
Back up everything you want to keep and reinstall the OS if possible.
Jan 08, 2009 | Compaq Presario Notebook
HP Compaq Presario v6000
Look in control panel - system - under hardware tab the : Device manager. in there is the network adapters open it from + sign and check is the cross marged on wireless driver if yes then its disabled u can use right mouse button to enable it
also you can find this thing under my network connections look is the wireless disabled or enabled if its disabled use right mouse button to enable it.
If it was helpful rate fixya
Dec 27, 2008 | Compaq Presario Notebook
Wireless switch
Here is all I know about Compaq Presario wireless switches. Sorry, but w/o a model I can't be more specific.
Compaq Presario, Model not specified - Button on the Back
C304NR - Button on upper right above keyboard deck, Blue is enabled
CQ Series - Button above the keyboard (antenna icon on button) next to power.
** CQ50-107NR (Conflicting reports on this model show:
Button above keyboard (antenna icon on button) next to power or lighted button below space bar that turns the touch pad on/off.
M2000 - Button above the keyboard (antenna icon on button)
Dec 11, 2008 | Computers & Internet
Compaq pressario X1000
if u turn on the wireless button and there is a wireless connection somwhere in range then you will be able to connect to it with out the button on then you will need to connect a wirteless device such as a wireless usb device that is what i am running on right now as i type
Aug 20, 2008 | Compaq Presario Notebook
Problem in driver notebook compaq with xp
try this driver.
http://www.belkin.com/support/article/?lid=en&pid=F8T003&aid=5239&scid=0
Aug 07, 2008 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
yes. when the switch is turned on it activates the built in wireless card in your laptop. you can then connect to a wireless router
Jun 10, 2008 | Compaq Presario X1000 Notebook
My wrieless network connection is properly installed but i can not connect internet using my laptop
Dear Ditditong,
First is your wifi switch on the compaq enabled. It is suppose to be lighted and an icon on the task bar will tell you it is.
Second, check your Wifi OS set-up if properly done ; if not use the windows wizard to accomplish this.
Third, Make sure your D-link has been properly set-up for wireless set-up to be able for you to access the router. The manual might have information along this line.
Sidlahora
Jan 26, 2008 | Computers & Internet
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
