Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Error code frige has error code IF doesnt make ice and have already replaced the small circuit board
  • 725 Answers
IF error is a bad fan motor or wire connection to the fan motor that is use for cooling the ice maker
Posted on Aug 31, 2008
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
My Amana ACB087 airconditioner shows a code E1 when I plug it in ,why is that??
E1 error is a restriction of the air flow entering the filter area. It also could be a defective Printed Circuit Board AKA PCB. Try this Remove the front cover and check the temperature sensor and the ice sensor (This would be a black wire attached to a small sensor that is inserted in a small copper tube in the cooling coil). The temperature sensor would be the one in front of the cooling coil. Black wires also and has a shiny tiny thing at its tip. These two sensors could be damaged or has lost its connection to the main board. These error codes would likewise just sense these sensors also called probes here in the USA that communicate the cooling of the unit to the Electronic Circuit Board. Hope this helps, Thanks, Sea Breeze
Jul 04, 2011 | Amana Heating & Cooling
Ice maker not working properly & Ice cycles in freezer
THIS IS WHY PEOPLE USE THIS SITE.ORDINARY PEOPLE NEED FRIENDS TO HELPOUT....
find an elderly person in your area that needs help, not charity.the feeling is priceless...
Feb 11, 2010 | Freezers
My whirlpool gold frige ices up and doesnt keep refrigerator side cold
The most likely problem is mthe part number W10135899 defrost control board. Next likely is the defrost heater and the defrost thermostat. Thanks, Sea Breeze
Oct 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Jun 26, 2009 | Comfort-Aire BHD-501 Dehumidifier
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
