Question about Fujitsu Siemens AMILO D-7830 Notebook
Lap top - intermittent power
I have a Fujitsu D7830 laptop which has 2 problems which may be connected. Firstly, the battery will not charge at all. Secondly, if I use AC power, the moment I move the laptop or wiggle the power lead at the rear of the unit, the power fails and it dies. When trying t oturn back on, it sometimes takes 2/3 attempts for the green lights to come on. Any ideas?? Many thanks.
    Sergeant:
    Champion:
  • 256 Answers
Try changing your power adopter....
Posted on Sep 14, 2008
Hi again! My previous solution might not work :-(
Seems that my problem is identical with yours!
I have noticed, after open the bottom that the soldering of the DC-connection is lose on the motherboard. So the solution might be to take the computer apart and heat up your soldering-iron. Well god luck again!
Posted on Aug 31, 2008
Hi!
Sound like a similar problem I have/had...
Mine started but always died after a period of time, and the timeframe varied. I was not sure at first that it wasn´t a heat problem, because CPU temp reports constant of 75deg celcius.
I removed the battery and at first it would not start (same as usually after it died) but after a few attempt it booted fine (also as usual). I have tried to start the laptop with the battery in place to repeat the problem but it didn´t. Battery was still not charging so I removed it again and PC is running fine since. God Luck
Screen total black out
turn your lap top off, take out the battery, hold your power button for 30-60 secs, turn it back on and PRESTO!
Feb 13, 2012 | Fujitsu Siemens AMILO Pro V2010 Notebook
Hi, I have a question, or reset the BIOS Fujitsu Siemens Amilo d7830 is safe by removing the battery on the motherboard and is it possible otherwise.I want to do this because I have a problem with a laptop...
Yes you should be able to use the laptop plugged in and no battery installed. You should try to find new battery on ebay. You might just find the battery for a great price. Good luck
Feb 25, 2011 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo D7830 totally dead; Been told it could be the main battery (Not the CMOS); Replace the battery, and the laptop could start to work...Problem I've got with that is obvious, I don't want to buy a new...
IF YOU ARE ABLE TO BOOST THE BATTERY, THEN YOU CAN TRY..USING A MULTIMETER CHECK THE VOLTAGE OF YOUR BATTERY, OBSERVING THE POLARITY...TRY TO GIVE 12VDC CURRENT TO THE FOR 30SEC OR A BIT MORE, ONCE THE POWER IS PICKED FROM BOOSTING , COULD HELP IN CHARGING AND IT CAN ON YOUR NOTEBOOK.....
Oct 15, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Battery charger fine but lap top shows not charging
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 10, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop battery dead
nope, battery can die even if always on AC power with battery installed. Time to replace the battery. sorry for the bad news.
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
D7830 Amilo
There can be a number of reasons for this, Check out these options;
Switch Memory over, failing that test one at a time. Plug in an external monitor. Check the Bios Settings and Bios Battery. You can find other tips at: www.powerjackrepair.com
Nov 28, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Charging Fujitsu Siemens D7830
Have you ever replaced your AC Adapter, if yes than replace AC Adapter with an OEM....
Jul 22, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
New Battery installed but until 3% only and stop Charging
problem with mother board
http://www.fixya.com/ThreadView.aspx?prdid=550269&thid=766742
Jul 17, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Amilo d7830 hard drive
Yes, you can up to 120 GB IDE 2.5" HDD. You can buy it from any PC store near you ar order online.
Hope this Helps.
May 08, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens AMILO D-7830 Notebook Logo
328 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
