Question about HP Office Equipment & Supplies
When printing the top of letters are cut off - HP Office Equipment & Supplies
  • madk Aug 21, 2008
    thanks for your help
  • 100 Answers
Probably it is just your paper setting ( mostly is a4 to letter)
you may check the printing preferences and the settings of your print device.
Posted on Aug 21, 2008
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
When printing word documents it spaces the text down about two inches from the top, cutting it off at the bottom. It seems to only do this when the text is double spaced. I tried to reopen and print again,...
Have you used page setup in words? is it a problem of A4 or Letter page size? If you have A4 as default in Word and Letter as default in the printer it would react that way (letter is wider while A4 is longer...)
Jul 28, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
IBM Personal Wheelwriter 2
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
DickyO
Jul 02, 2008 | IBM Wheelwriter 30 Typewriter
Tops of characters cut off
Go to www.fixyourownprinter.com for expert help on this particular problem
Jul 12, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Won't print out legal size paper
some machines have a setting on the tray as well as in the menu. I would check both.
Jun 19, 2007 | Xante Accel-a-Writer Laser Printer
Tops of letters are cut off when printing.
This is usually caused by clogged or burned out printhead nozzels. You can try putting the unit through a couple cleaning cycles. If that does not help, then replace the cartridge with a new HP BRAND cartridge. Do not trust refilled or compatible cartridges in this case. The heating elements in the individual nozzels can burn out causing your type of problem. Let me know one way or the other Ed
May 30, 2007 | HP PSC 1610 All-In-One InkJet Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
