Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Spacer for back of Range
Does Jenn Air make a spacer for a slide in downdraft electric range?
The unit does not sit flush to the back of the Island opening.
I had an older Jenn-Air range in this spot and they had made a spacer to fill this one inch type opening.
5 Suggested Answers
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
SOURCE: outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Posted on Dec 09, 2008
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: I have a jenn-air 30 inch downdraft electric slide
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Posted on Sep 22, 2009
Jenn-Air 30" slide in modular downdraft electric range completely stopped working. Household circuit breaker functioning, range is getting power, no apparent malfunction to power connection which is hard...
Well, it's either all the burners are burnt, or power is not getting to the unit. You have to check where the power stops. Fuses/breakers on the unit? Bad switches? Loose wire?
May 13, 2014 | Kitchen Ranges
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Is there a vent cover for the downdraft vent. The
not that I know of but the fans on these ranges usually have multiple speeds. Try using the lowest. The fans are very strong on them. Hope this helps. good luck.
Nov 26, 2009 | Jenn-Air SCE30600 Slide-In Electric...
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
Jenn-air electric range model JES9800AAB some kypad # not working
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-air downdraft blower doesn't work
thiknin thats a sealed unit, however imn sure they got it into a housing so i guess if you lloked close enough ther ewpuild be a few screws to gain access to the fan itself and with it open a quailty degreaser should work wonders in cleaning it!
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
345 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
