Question about Creative Labs Zen V MP3 Player
Zen v plus
Willnot come on frozen It always says low battery, even when charged for hours through USB.
IT FREEZES ON THE ZEN V SCREEN and DOESN'T SHUT OFF UNTIL IT DIES COMPLETELY! PLEASE HELP ME!
  • Anonymous Apr 12, 2009
    I have two of these devices - one for each child neither of them will do anthing except display 'Low Battery'
I already tried that a million times. that only shuts it off. thanks
Posted on Sep 05, 2008
On my mp3 player,display is not working,while i am able to listen the music,but not able to see the menu and options
Posted on Sep 04, 2008
Have you tryed rebooting at bottom lefthand corner with pin.
SOURCE:
Zen V Plus freezes only when certain tracks are played -
First place the Zen in the freezer to help the firmware to stiffen up. Once frozen place in microwave for 25 seconds. This will reset your device and all should be good.
Sep 19, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen v plus 8g
If you already try both reset, then try doing a firmware update.
On computer try unplugging computer power cable, and if it is a laptop also remove battery, this sort out problems related with electrostatic charges on computer USB ports.
Sep 14, 2008 | Creative Labs ZEN V Plus MP3 Player
When I plug it in to charge the player, it says "docked" as usual, but then it turns itself off and acts like I've disconnected it. It says "Low Battery" and shuts down.
The zen need a full charge... if you have an ac adapter plug it in for at least eight hours. if you don't have an ac adapter plug it in via USB to a DESKTOP computer (not laptop) and try to use a differnt usb cord (creative doesn't always include a powerful enough cord to get the zen out of that low power state)
refer to creative.com/support and look up info on your model to see if anyone else has your issue
May 26, 2009 | Creative Labs Zen Digital Media Player
My Zen V Plus is really screwed up
Sounds like a similar problem I had today.
My Creative Zen V Plus wasn't recognised by my PC, then it wouldn't even switch on.
Following the solution of another similar problem on here I fixed it. Connect your Zen via USB to your computer and press the reset button. Should spring to life and start re-building your library. I am as I type adding new tracks to mine :))
Apr 04, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Help frozen up zen vplus 4gb
I had the same repeating problem with my Zen V Plus 2GB. There is a tiny hole on the left side of the player, underneath the on/off switch. Stick a paperclip in there and press gently to reset your player. I lived for 6 months letting the battery wear itself out before I discovered this reset hole. I finally found the offending piece of music and deleted it from the player. I haven't had any problems with my Zen freezing since deleting that song. Pay attention to whether it always freezes on the same media, that might be the source of your problem.
Hope this helps!
Jun 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen stone 1GB low battery even after charging
go and delete some songs by this your zen memory is free.
and go to adjust power property and select the right power management for ur eqipment.
Jun 22, 2008 | Creative Labs ZEN V Plus MP3 Player
ZEN MP3 ( frozen)
If it has frozen Chances are it'll do it again so i suggest you take out your warranty and exchange it
Jan 15, 2008 | Creative Labs Zen Digital Media Player
Creative zen V 1GB
Boy's will be Boy's....
try this
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Dec 08, 2007 | Creative Labs ZEN V Plus MP3 Player
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Creative Labs Zen V MP3 Player Logo
110 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
