Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart brew on demand coffee maker
Hi, my niece was just housesitting for us and when I returned from our trip, the coffee maker refuses to work, she tried to us it yesterday and no go.  I have always just used it on manual brew mode, and so have tried this morning to set it to brew a couple of minutes later on timer, but still no go. Any Ideas?? Elisia
  • 4 more comments
  • delgo Aug 23, 2008
    My model is actually the one with no carafe.
    Hi
    It is actually model DCC 2000C
    There is no glass carafe, and I usually run the gold filter through the dishwasher, would this not be enough to clean it?
    This did nothing, I also checked the outlet to make sure that nothing had tripped the breaker.
    I plugged other elect. appliances into this outlet, and they worked fine. So it is nothing to do with the power source at the wall,
    No problem with the power supply at all
    Master:
  • 623 Answers
Get your manual here
kitchen.manualsonline.com/manuals/mfg/cuisinart/dcc2000c_series.html
Posted on Aug 23, 2008
    Genius:
  • 1,269 Answers
Maybe the power cord itself is burnt. If you have an electronic tester you can check it by shorting both poles of the power plug if it still functions fine. You can replace the power plug if found defective.
    Sergeant:
    Champion:
  • 236 Answers
Do you hear the water moving?
if not,
you could try to flush the system by putting in boiling water in the reservoir without any filters or coffee. let it all drain out.
Do you hear the water heat?
is the reservoir casing hot when turned on?
If its not hot, your heating mechanism might have gone out. unless you want to send it for repair or open it yourself, Boil the water and run it though the coffee and filter.
  • Cuisinart Master
  • 19,396 Answers
First unplug machine from power, this will solve electronic problems by resetting the machine, in case it is not completing brewing cycle.
Check if water is being pumped to the filter.
Check for lose pipes inside machine.
If hose are obstructed machine may need to be taken apart and cleaned.
  • Ginko
    Ginko Aug 23, 2008
    You need to undo internal pipes and blow them with compressed air, from description seems an obstructed hose, pump should be ok.
  • 1,879 Answers
Try another outlet - still doesn't work, have it serviced (fuse blown for example)
    Master:
  • 848 Answers
The gold permanent filter must be cleaned so
Try this:
Remove the filter basket from the coffee machine.
Remove the gold permanent coffee filter from the basket.
Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
Fill the water reservoir with the desired amount of water.
Add the desired amout of coffee grounds into the paper coffee filter.
Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
Ensure the glass carafe is placed correctly in its position on the heating plate.
Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
  • Anonymous Aug 23, 2008
    The thermal breaker might have died in it. This is usually mounted on, or near the heating element and usually turns off when excessive temperatures are present It can be checked with a ohm meter on its contacts. If it shows as good, it should show up as normally closed. Some overtemp breakers have a small button for resetting, but most are simply supposed to reset themselves once the heat is sufficiently reduced. There are also heat fuses that blow...for good when excessive heat is detected, mounted in the same place, they are often a metal bullet shaped tube.
    or .....your power cord...or main power switch could also be faulty............
    Genius:
  • 1,011 Answers
What about on/off switch, does it seem ok.
regards,
dont rate it untill fully satisfied
  • SALMAN NASEER Aug 24, 2008
    is it doing nothing, even any indication for power ON.
    check it by the way.
    regards,
SOURCE:
Why do I get so many coffee grounds in my cuisinart on demand coffee maker?
Many times this is a result of the coffee grind. To overcome this with some brands, I use an additional filter, put the desired amount of coffee in it, and then fold the sides over to make an envelope. Place the folded sides down and brew coffee. If any of the coffee gets out, the second filter should catch it.
Mar 25, 2015 | Cuisinart DCC Coffee Makers & Espresso...
I have a Cuisinart DOC-4000 Coffee on Demand Coffee Maker. it no longer brews will not pump the water from the resivor tank to brew the coffee.
Fixing appliances is a dying art, and parts can be hard to get. Buy a new cheaper coffee pot. We've broken so many carafes that we won't pay more than $12 or so for a new coffeemaker.
Dec 22, 2014 | Cuisinart Coffee Makers & Espresso...
I have a Cuisinart Coffee on Demand maker and it will no longer brew. Its less than a year. How can it be fixed?
mcdevito75 here, May need to be cleaned a swater will leave deposits, refer to owner manual for cleaning.
Jun 22, 2010 | Cuisinart Coffee on Demand 12-Cup...
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Won't Brew
Unplug for 20 minutes or longer - this one has a longer-than-normal reset.
Jan 05, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
My coffee grinder on my new machine is not working
Who is this mp3doctor anyway? This person must work for Cuisinart. Same posting for all of my searches. My grind and brew worked ok for the first year and then began having issues. Not grinding in any mode. If I stand over the unit and program it for several times it has worked. Seems to be an electrical issue that many other owners have.
Do not need the doctor to suggest that we should have better luck with buying another of the same. The odds are good for the game players not the consumers. We need solutions not marketing alternatives.
Our stainless Cuisinart looks great on the counter but thats about it. Had to take another morning trip to DDs. Tired of playing with this lemon!
PaulKB
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My DCC-1200 won't turn on
I called Cuisinart. There is no way to fix it. If your coffee maker is still under warranty (3 years) they will replace it. Otherwise, its next stop is the landfill.
Dec 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
437 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
