Question about Whirlpool Refrigerators
I have a 10 year old side by side refrigerator. Model No. ED20TKXDN01., Ser. SG0437491. The freezer portion works fine, plenty of cold air. The refrigerator portion is not staying cold, food is spoiling. Vents in the frig are not clogged, but no air coming out of top vent.
    President:
  • 1,462 Answers
Take back panel off inside freezer and check if there is ice build up. if so, melt off with a hair dryer and see if it works then. get back to me if you want
Posted on Aug 21, 2008
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
Refrigerator and freezer not staying cold
call a repair service and get it checked , might need recharged with freon and only certified people can do it
Jan 30, 2018 | Jenn-Air JSD2690HES Stainless Steel Side...
My refrigerator wont get cold and it is on the highest temperature possible the freezer is working fine. its still makeing ice but its just that the refrigerator wont get cold. its also 10 years old.
Always set the controls to their "normal" recommended setting. Changing them will not work. Is there air blowing from the freezer? The freezer fan may not be working. Or if it is, possibly the air flapper could be stuck closed not letting air flow into the refrigerator.
Dec 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
All of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Apr 18, 2009 | Refrigerators
Whirlpool side by side refrigerator not cooling
yes do the check for the baffle. set the controoler for the thermostat to off and the freezer to the coldest setting while have the doors open. take the cover off the baffle and observe if its closed . should close in 10 seconds, also the compressor should be on, as should the evaporator fan and the condenser fan. turn the controls the oposite and the baffle should open. Also make sure that you have seperation of product so that you haev adequate air flow in frig.
Feb 05, 2009 | Kenmore Refrigerators
Refrigerator not working
Hello dooz127,
You have a coolant leak some where.
How old is your fridge?
huuum,happy to assist you!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Aug 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
128 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
