Question about Gateway 7330GZ Notebook
Numbers and backspace on Gateway 7330GZ not working
The numbers line and backspace on the keyboard will not work. If the num lock is turned on then 6,7,8,9,&0 will work. Any suggestions? I have reinstalled the driver already.
    Genius:
  • 2,028 Answers
You might check and clean the keyboard connection to the motherboard. However, usually this indicates keyboard failure. It's most likely that you're have to replace the keyboard.
Posted on Aug 21, 2008
SOURCE:
Num lock not working. number keypad not working. keyboard numbers are working.
Press the num lock button - usually the top left hand button on the keyboard numbers on right hand side of keyboard.
Mar 02, 2016 | Logitech Computers & Internet
Acer laptop number keys on right not working.
You have hit the num lock key. Lookin at pictures I could find on the internet, the Num Lock key is next to the backspace key, and above the number 7 key.
Hope this helps
Mar 30, 2012 | Acer Aspire Computers & Internet
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Why do I get a 1 when I type a j?
Hi, this is becasue your "num lock" key is truned on. on laptops there is no numer keypad so when you press the num lock key some of the letters do double duty as numbers. Just press the num lock key again and it will turn your keyboard back to normal.
Sep 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
My Gateway laptop - 2 yrs old - just developed problem - some letter keys actualy type numbers ... eg "M" becomes zero,total of nine, while the zero number key types"/". Help!
Sounds like you have turned on the NUM LOCK on the laptop keyboard. If you look closely you will see the numbers on those keys (maybe in a different colour).
You need to turn off NUM LOCK again. On the laptop I'm looking at, this is done by pressing Fn and END together, but the key should be marked with NUM LOCK as well.
Apr 16, 2010 | Gateway 2520915 Keyboard
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Typing numbers instead of letters
Your keyboard has "extra" keys:
* print-screen / system-request
* scroll-lock
* pause / break
* num lock
Press that "num lock" key.
For a laptop keyboard, you may have to hold down the 'FN' key,
at the same time that you press "num lock", to enable/disable this function.
Jan 02, 2010 | Gateway 7001433 Keyboard
There is no key for numlock on my Dell studio 15 keyboard
The num lock key is labeled as 'Num Lk' on the Dell Studio 15 keyboard. It is located above the =/+ key next to backspace.
To activate num lock, you cannot just press the button. You have to make sure the num lock light is on and then hold down Fn while using the numpad.
Hope this helps,
Tiger720
Sep 02, 2009 | Dell Studio 15 Laptop
My Gateway keyboard (#2520796)
Is your Num-Lock Key working?
Jun 05, 2008 | Gateway 2520796 Keyboard
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
Gateway 7330GZ Notebook Logo
145 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
