Question about Intermec EasyCoder PC4 Label Printer
Easy coder We have entered label size - but it prints off centre . We did the recalibration instructions - now we have a green light but can not print label
    Scholar:
  • 45 Answers
Switch off the power. Hold down the Feed button while you switch the power back on.
After the Configuration label prints, turn the power off and on again, then try printing again.
Posted on Sep 24, 2008
Error print after few labels
Check if the label size is correctly entered.
Else Try to recalibrate the cells.
Mar 31, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
When printing 1 label it will print but 5 blanks shoot out behind
Different reasons.
- the size of the label is wrong.
- You are writing too low on the label( too near the edge)
- You have to recalibrate the gap sensor.
Feb 14, 2011 | Datamax E-CLASS DMX-E-4204 Label Printer
Zebra Eltron 2844 is not printing 4x6 shipping labels. I am using the printer to print FedEx labels. i recently had to reinstall the driver, and now when I print, it prints just under 2x4, rather than the...
You can recalibrate it to read the label size by doing the following.
Power off the printer
Hold down the green button
Turn the printer on and about 1/2 second after turning it on, release the green button
It will print out some information and measure the label. Once it stops, hit the green button one last time and then try to print another label.
Jan 26, 2011 | Office Equipment & Supplies
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Mar 31, 2009 | Toshiba TEC B-472 Thermal Label Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2824
the error you are getting is a label size error. a label variance of as little as 1/203th of an inch can cause this.
you need to recalibrate the printer to the media, hold feed when powering up the printer letting go once the light flashes 4 times. this will force the printer to autodetect the label size.
if you are specifying the label size in you software or driver settings, measure and double check the label size
Dec 04, 2007 | Zebra TLP 2824 Printer
Skipping 1 mm (regular intervals) while printing labels
1-try to recalibrate labels
2-make sure the label size is correct in the settings:
here is the link for the driver. :
http://barcode.toshibatec.co.jp/Eng/download1.html
Nov 02, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
417 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
