Question about Sharp Notevision PG-A10X Multimedia Projector
Sharp Notevision PG A10X
The power light and lamp light was flashing red. now the projector don't come on at all what could possibly cause that. if the lamp goes bad would that stop it from come on
  • 1 more comment
  • Anonymous Oct 29, 2008
    it could mean that the lamp is out.
    just happened to me. got new lamp. worked for a week and now doesnt turn back on
  • rshawnego Jan 18, 2009
    my projector wont turn on at all, how do i know if the Bulb is the problem!!
    I have the same problem with no power on,,, not working
  • rgarza Jan 30, 2009
    lamp looks good ,but yet no power indicator lights up. fuse ok
Check the power supply heard issues with this system like that but was all related to the power supply
Posted on Jan 24, 2009
What can cause my sharp pg a10x not to have any power at all
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 24, 2014 | Sharp (BQCPGA10X1) Projector Lamp for...
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
Replaced lanp and the unit will not power on
you need to reset the lamp timer. hold down the enter, down, and menu, then press power.
Dec 17, 2009 | Sharp Notevision PG-A10X Multimedia...
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Nov 09, 2008 | Sharp Notevision PG-A10X Multimedia...
Sharp notevision PG-C45X will not turn on
possible blown lamp I think that is what the flashing red light means check manual
Oct 03, 2008 | Sharp Notevision PG-C45X Multimedia...
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Projector
Does the temp. light come when it switches off ?
Check if all the fans are running when switched on.
If all the fans are running - take out the lamp and check if you can see any irregularity on the shaft of the lamp's insides.
If not then you will most probably have the Ballast ( Lamp's powersupply ) replaced or repaired
Apr 02, 2008 | Sharp Notevision PG-A10X Multimedia...
Open Questions:
See all Sharp Notevision PG-A10X Multimedia Projector Questions
Sharp Notevision PG-A10X Multimedia Projector Logo
520 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
