Question about HP Pavilion dv6000z Notebook
KEY FELL OFF
F11 KEY FELL OFF...HOW DO I RE-INSTALL?
  • 186 Answers
If you have all the components of the Key, it is eazy to reinstall it.
If you miss any minute component, it is not that easy to replace the popped key.
You can find some instructions about replacing dropped keys of Notebooks from the links below :
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
and
http://img236.imageshack.us/slideshow/player.php?id=img236/1114/116274244563s.smil
If you donot have the required parts of the key to refix it, I recommend you to contact any nearest Service Center and get the required parts or get the key fixed.
Hope this helps...
Posted on Aug 21, 2008
I have a hp paviliona1340n and the screen comes on an shows the hp logo,but then the screen goes black and says reboot device and press any key, what can i do to get my computer running back to normal
a1340n,windows what?
this pc Desktop is now retired at HP, no support. 12 years old now.
that depend on 2 things what is wrong.? (hdd or OS dead)
came new with XP the dead OS>.
if you have the HP hot key f11 working
or of you have the HP install media kit for it.
i guess the screens ok, and BIOS is OK, hit the bios key yet? power on hit what the screen tell you, at power on.
if that works and the OS fails to boot?
that means the startup files are bad on hdd
or HDD is bad
or the OS is corrupted.
what I do is boot to linux live cd/dvd or usb stick
if that works we know the HDD is the problem in 1min flat.
the we, hit f11 at power on and pick restore, and pick
the 2005 is us on the cusp of having F11 working or not
F11 is the key that has the full XP install on the HDD.
we run a linux (knoppix 7) DVD there and do the DISK test there.
if that fails the HDD is bad.
see it run here, this live DVD OS is the best test disk around.
and 100% free. if you can burn it or burn to USBSTICK mem.
http://www.pcdied.com/brick-dead.html#Knoppix
running knoppix tells me pc is ok
and at same time the HDD is good or bad.
if the F11 key works, then if lucky you can do repair restore.
or a start up file fix.
F11 runs the HP restore partitions,
id read you service Guide for you and look but HP deleted it.
Aug 08, 2017 | HP Computers & Internet
Tip
Sylvania Netbook F11 and F12 Key Function
You may need to download and install the latest BIOS update for this function to work, but here it the key combos for both the F11 and F12 function keys.
With the latest BIOS update, Fn+Z should be F11 and Fn+X should be F12.
BIOS Updates may be downloaded at:
http://www.sylvanianetbooks.com/
on May 15, 2011 | Computers & Internet
F11 doesn't work as fullscreen toggle for Windows 8
Have you tried the fn key (bottom left, next to ctrl key)?
On my HP laptop running Windows 8.1, pressing f11 mutes the speaker (as per the logo on the key top) and fn+f11 in IE & Firefox toggles full screen.
Jan 06, 2014 | HP 2000-2a10NR Notebook B5R65UAABA
Hp blue screen says "entering setup ..." but it is locked up instead
ok, an A6512p0b PC desk top.
VISTA.
HP media kit,? a real kit not using home made kit? from HP.
New HDD causes the F11 key to go dead (or F10 older PC)
F11/10, is the VIRTUAL install CDs/
HP put the install CDs in its own hidden install partition.
making the f10/11 key run that virtual CD installer.
now you have a new HDD, and guess what, all that is gone.
so step 2 is what, REAL MEDIA KIT. from HP.
HP has a huge pages on this, every step every way possible to restore, at hp.com ever see HP.com?
what worries me is this statement by you/'
"but cannot open BIOS." this is serious all screens must work.
you can remove the HDD and CD drives and BIOS always works
BIOS IS IN ROM, it always works or it has very very serious problems if it is DEAD. BIOS DEAD.
the screen is not dead, you see its works.
like:
  1. PSU bad.
  2. CPU overheating or heat sink bad or fell off.
  3. memory bad, try 1 stick at a time?
  4. other things plugged in to mobo that are shorted..
  5. mobo bad.
  6. GPU card bad or has problems if it has one. see #4
  7. desktops can have lots of things added, i cant see yours. inside/.
the correct kits are from HP, here.
comes with all drivers, and all HP apps. and is turn key.
https://support.hp.com/us-en/document/bph07143
there are other ways to do this, using MS disks and long day of work.
ill not teach that here.
Jun 23, 2017 | HP Pavilion a6512p-b PC Bundle PC Desktop
What keys do i push to get f11 on a sylvania netbook
My f11 keys doesn't work and can't turn on my wireless.
i suspect your f11 key does work, try opening a web browser and while it is open press the f11 key if your browser goes full screen the f11 key works just press f11 again to return it to normal. Try pressing and holding the fn key and then press f11 that will switch your wireless on and off
Mar 30, 2011 | MSI GX630-028US Notebook
HP Pavilion s3407c, F11 key fail to startup system recovery
windows corrupted maybe try to reformat your pc and install back windows.but dont forget to take out your hardisk and backup your important things ok
Jun 06, 2009 | HP Pavilion Slimline s3407c Desktop,...
LOOSE KEY
Set it on the space where it should be in the correct way then gently pop it in. Look on the key if there are obvious stress points where it possibly broke. If there are none then it should pop in correctly. If not you might have to use some type of adhesive.
Aug 21, 2008 | HP Pavilion dv6000z Notebook
F key came off
1.
If you have the key retainer (image) you can find some good instructions on the webpage.
2.
If you do not have the retainer you will have to buy either the key or the entire keyboard from ebay. As of Jan 1 there are no keys available for acer keyboards but the entire keyboard is available here and here.
Dec 16, 2007 | Acer NSK8458AN Keyboard
HP Pavilion dv6000z Notebook Logo
281 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
