Question about Ricoh Office Equipment & Supplies
The printer does not print black well. The color cartriges print fine. I have already tried changing the printer cartridge.
  • Ricoh Master
  • 1,879 Answers
Perform a head cleaning - check your usaer manual on how to do it.
Posted on Aug 21, 2008
SOURCE:
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
Printer will not print!
Didnt I just answer this question?
Your printer doesn't know what you are printing ... the color is empty ... so the printer is preventing what it thinks is an error ... because, as I said, it doesn't know what is coming. Replace the color cartridge andthings will be fine.
Mar 19, 2010 | Lexmark X3350 All-In-One InkJet Printer
How to print black and white only on Konica-Minolta 2400W
Are using OEM cartridges? What about the transfer belt and transfer roller have they been replaced>
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 26, 2009 | Konica Color Stationary Workgroup Laser...
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Color won't print! Test shows continuity.
I stand corrected, but this sounds strange. The black cartrige on a 650c is a no40, the colors are No50. It is impossible to place a color cartrige in the black posotion. You must remove all your cartriges and wipe them off at the bottom with a very hot wet cloth (not boiling) Let them stand on the wet cloth for quite some time and then give them a good shake (dont be shy). Be VERY careful not to get ink on your clothes or nearby objects. Once you have done this wipe them down again with a dry lint free cloth or tissue paper and try again.
Dave
May 18, 2009 | HP DesignJet 750c plus InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Open Questions:
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
