Question about Xerox Office Equipment & Supplies
I replaced the drum on my Xerox Work Centre Pro 416P. Now when I turn it on the LED screen has a line through it and the unit just clicks, does not really power up. Is there a reset switch somewhere?
  • Anonymous Mar 22, 2014
    need to reset
    President:
  • 2,072 Answers
That sounds like the corotron assembly in the cartridge is shorted.
Posted on Aug 21, 2008
How can I get "clean" prints without marks on a Xerox Work Centre 7428?
Hi Tommy yea that is usually a image unit problem. Looks like the drum is scratched up. I looked at the pictures looks like the cyan image unit is bad. Take them out carefully... and keep them away from light and you should be able to see that chip in the drum. Might be hard to see it. We sell those image units iteminconline you can also give us a call and we would be happy to help you.
Sep 03, 2014 | Xerox Office Equipment & Supplies
Xerox Work Centre XD120f - J2 error message. Lost manual need new one.
J2 means the drum unit has reached the end of its life. You need to replace it.
Staples . office max etc normally has them in stock.
If not google a company called The Parts Drop.
They will have what you need also.
Oct 24, 2010 | Xerox Office Equipment & Supplies
Ir 3100 colour xerox i faced master copy centre white lines
hai my name is aslam u will change thr drum unit or ITB unit
Sep 14, 2010 | Canon iRC3100 Printer
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Getting J2 on the screen copier won't work
That means the drum cartridge has reached the end of its life.
You can replace the drum unit or the chip on back.
You can google a business called "the parts drop."
They should have both.
Jan 19, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Copies are very dirty from xerox c2636. Really dark cast of magenta on each copy.
1) magenta drum has already reach life span.
2)poor cleaning of magenta drum process unit.
3)recommended to replace the mageta process unit.
Sep 09, 2009 | Xerox WorkCentre Pro C2636 Color Copier
What causes j 7 error copde in xerox workcentre Pro 423 and how is it cleared
by replacing the drum unit or replacing the crum the code j7 will be cleared
Aug 13, 2009 | Xerox WorkCentre Pro 423 Copier
Xerox 416P faded copies
Remove the glass and thoroughly clean the lamp, mirrors and lens. Also the glass on both sides. If that does not work, remove the toner and drum, look inside the machine for a small opening about 8 inches long and a quarter inch wide. That is the laser window. It may also need cleaned. It is possible the laser needs to be removed and cleaned.
I am not sure, can you print reports on the p model? If so make a printed page and tell me if they look fine.
What you have to remember on a digital copier is when the optics get dirty , the image gets lighter.
Mar 17, 2009 | Xerox WorkCentre Pro 416Pi All-In-One...
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
Xerox workcentre pro 416dc
You may have over packed the toner....take it outside and empty it onto newspaper carefully! Shake the unit the loosen any hard pack, then try it in the machine ..if it is now quiet put HALF thetoner back.....if it is still noisy you might have busted the toner drive auger it's made of the 20th Century wonder material plastic
Jun 20, 2008 | Xerox WorkCentre Pro 423 Copier
91 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
