Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Tried having the ic's replaced but still doesn't work
I had the ic's and resistors all replaced but I think they burned the board in a couple of spots where the ic pins go in. Is there a way to fix this or do I need a new board?
  • 23 more comments
  • LEEBEE72 Aug 21, 2008
    How expensive would it be and where can I get a new board?
    My tv model# is pt 53wx53g Panasonic and the board is tnp2ah046.
    where can i get the board and is there a different board that can be used if I can not find the one I already have?
    There are certain spots that the solder won't even stick to the board I belive because of how it is burned. Is there still a way to fix this
    Anywhere else that may have the boards?
    Anywhere else?
    I can not get a picture but the burning is so bad that the solder will not stick to the board.
    fixmymonitor.com doesn't have parts.
    why do I need a professional?Is the board to hard to replace?
    can't find it on tradekey because I'm not sur if I was in the right section
    Is the board hard for a non professional to put in?
    Can I install the board myself or is it difficult to do?Does anyone have any instructions on how to do it or tips?
    The panasonic link you gave me says I need to request access for the online store.
    I replaced the ic's and all the resistors but it still blinks 3 times and so I replaced the ic's again and noticed where some of the solder didn't stick to the pin holes because I believe it was burned.
    It looks like all you have to do is unplug all the wires and unscrew the board.Is there more to it?
    Thats what I figured and I thought there has to be a way to repair but how do you do it?I've seen kits online but is that what I need?
    The link you gave me for cmpalmer says it doesn't exist.
    Thanks I got link
    Thanks I got link
    Thanks I got link
    Got the link and that is what we did but it still blinks 3 times so I figured it was becasue of the burned pin holes.
    Well the first time I did not do it but I had stk392-150 installed as per someone on this site.But it blinked 3 times so I removed them and asked for more advice and was told to use stk392-120 and to replace all the resistors so I did.
  • LEEBEE72 Aug 27, 2008
    yes it is only 3 blinking lights,no picture or sound because it turns off after it blinks.
  • LEEBEE72 Sep 14, 2008
    where can I get the board and how do you replace it?
  • 2,294 Answers
If the pads are charred, then it becomes a bit more challenging to do the repair specially if you only done basic hand soldering.
Click here to see a short video on how to fix the broken pads or conductors.
See the last video titled: Plated Through Hole Repairs of PCBs, since the holes are already there ignore the drilling part but pay attention to the rest. From this point on, you will know if you want to attempt to repair it, buy a new one or send out for the broken pads repair.
I would estimate that a broken pads repair could be 1/3 of what a new board will cost.
Posted on Aug 21, 2008
    Genius:
  • 2,035 Answers
Use this link to get the new board:
http://www.partstore.com/Part/PTS/PTS/TNP2AH046/New.aspx
Good luck...
  • 10,594 Answers
Your required board is available HERE and its price is $358.35
Regards,
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Aug 21, 2008
    Its complete board with all parts mounted. just get and hook it.
    You can confirm and ask them is that board complete and all parts mounted on it? page shows the toll-free number.. 1-866-925-7278
    You right, Just unplug old board and plug connectors in new board, fix it with screws and that all. No more difficulty.
    Please lock my solution as fixya.
    Thanks n regards,
    Master:
  • 623 Answers
For parts
www.tradekey.com/ks-tv-parts/
  • ritchie dempacco
    ritchie dempacco Aug 21, 2008
    try here
    electronics.search.ebay.com/panasonic_Televisions_W0QQdfspZ32QQflocZ1QQfsooZ1QQfsopZ1QQsacat
    Z11071QQsaprc...
  • ritchie dempacco
    good luck
    Scholar:
  • 133 Answers
U have to go with a professinol tv repairer
  • 6,487 Answers
Try also checking it from this site http://fixmymonitor.com/
Good luck.........
  • 6 more comments
  • Mark Gil
    Mark Gil Aug 21, 2008
    In replacing the board needs extra care , so if you have knowledge in electronics I believe you can do it , But if not take all the necessary safety in changing the board or better ask someone who knows how to replace that........
  • Mark Gil
    Hopefully this will help youhttp://cmpalmer.blogspot.com/2006/11/fix...
    Check that link..........
  • Mark Gil
    Check the last link that I gave you if you think you can do something like that go ahead and replace the board by yourself...
  • Mark Gil
    Yes, that what you need,did you already check the last link that I gave you and see if you can do it by yourself??
  • Mark Gil
    It does exist check it again this is the link http://cmpalmer.blogspot.com/2006/11/fix...
  • Mark Gil
    Good and see if you can do something like that, if yes you can replace the board by yourself..
    Dont forget to rate my solution FIXYA....
  • Mark Gil
    Yes, that link is just to show you what you're going to do when you replace the board and see if you can do something like that.
  • Mark Gil
    Ok good now I suggest you go ahead and do it by yourself I think you ca do it...
    Good luck and thank you...
  • 4,234 Answers
Depending upon how much burning has occurred, the boards can be repaired. This is not a homeowner project though. I have repaired numerous boards in the last 20+ years. The charring itself should not be a major problem unless severe. CAn you post a picture of the area? Most shops won't do this type of repair. Only a few of us do this any more. Most shops don't even provide component level repairs, just board changes. Post the picture and your general location and I'll try to recommend a repair location for you.
Dan
  • 2 more comments
  • ABRsvcs Aug 21, 2008
    It sounds like the board "traces" are gone. This can still be repaired. That board is no longer available. Your only recourse is to have the module repaired.
    Dan
    Any repair kit will only include replacement parts. These kits assume that hte PC board itself is fine.
    Dan
    The 120s and 150s are pin compatible. The 150s can take more power so they would have been OK too. If changing these ICs did not resolve the problem, then we need to look elsewhere. Is the only symptom the 3 blinks of the standby light along with no picture? Is there sound?
    Thanks,
    Dan
  • ABRsvcs Sep 15, 2008
    Let me state this again as you may have missed it in the amount of garbage included here as solutions.
    The board you need is NO LONGER AVAILABLE as as assembly. There is a repair kit which will contain all of hte parts that usually get fried when the ICs fail. Based upon your descriptions here, either the board has some broken/charred traces or the power supply (another board) has some problems. At this point, it is unlikely that this problem will be resolved remotely. You will need to see a servicer. A look inside the set and measurements throughout the set need to be made to locate the problem and resolve it.
    Hope this helps,
    Dan
    Sergeant:
    Champion:
  • 298 Answers
Www.partstore.com/PartSearch.aspx?PartNumber=tnp2ah046&x=22&y=24
copy and paste ..this is a replacement d-board
please rate thanks.
  • 2,071 Answers
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
    Brigadier General:
  • 3,614 Answers
It seems that the board has already been damaged and burned, and you need to replace and install a new board for that.
  • 928 Answers
PC boards they are called have gold lines on them that serve as wires. If some spots are burned then the current will not pass through then that means that it will not work. You will need to change the board unfortunately. Although you might try a cleaning solution such as alcohol to clean off the burn marks and hope they work.
  • 11 more comments
  • Thomas Lim
    Thomas Lim Aug 21, 2008
    Panasonic is actually made by Matsushita you can call the number below toll free for parts. That is the number for a parts superstore
    1-866-925-PART (7278)
  • Thomas Lim
    As for the board i would suggest you use the exact same one for that unit as different circuits on the board behave differently and may not work with the other parts on the unit. If you are not familiar it would be best if you just have it serviced
  • Thomas Lim
    i sent you via an asked question for that its www.shopjimmy.com
  • Thomas Lim
    http://www.panasonicfa.com/?id=OEM%20Par...
  • Thomas Lim
    Copy and paste my links by the way into a browser
  • Thomas Lim
    Were you able to see the links that I sent you?
  • Thomas Lim
    Not really since you said your technically inclined it should be pretty straightforward and simple. When you purchase a board i suppose you could request for the schems as well
  • Thomas Lim
    The best tip is to take note of the current installation take a picture or something nothing beats that.... it gives you a better view than a schem diagram. Also take note of all connections
  • Thomas Lim
    Not really. as I said pretty straighforward. Thats why take note of the connections and your set
  • Thomas Lim
    Marked il just repost so he can get to it. Us the link below
    CMPALMER
  • Thomas Lim
    No problem just inquire if you have any further problems. Dont forget to rate this solution thread by the way
    Thanks
  • Thomas Lim
    Most likely so change board is the last option i suppose
  • Thomas Lim
    The burned pinholes most likely burned the connectors on the PC board
    Master:
  • 848 Answers
You need to get new board ..........because fixing will be very complicated and it will also be expensive ......
  • gopinath pasupathy Aug 21, 2008
    Its some what difficult for non professional because a slight mistake in placing a board and giving connection can leave you into lot of trouble ....
Need Circuit Diagram, or convergence resistor list for PT51D31CE
they are 2.2 ohm , i have replece many of this before
Apr 19, 2010 | Panasonic PT-51D31 TV
The screen is very dark and I am unable to see any image (although there does appear to be some very faint lighter spots, but these are not really discernable)
Hi
Thanks for using FixYa. Heat is the number one enemy of electronics, and these sets operate hot. This problem is caused by the power supply being overloaded. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can has a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 05, 2010 | Televison & Video
Hi! Folks I need to identfy the SOIC-8 IC that lies between the 2 an 3 pci slots. In my board this IC burns up and became unreadble. Thanks a lot for any help. nelsonrosa_junior@hotmail.cm
That style of package is used mostly for terminating resistors and small-value capacitors. The fact that is burned indicates resistors so you may be able to remove it and try measuring between first and/or last pins to those between. If you get a couple of close values, it is probably a seven resistor pack. In some configurations though, the common pins are not at the end(s) some you may have to experiment and measure between pins until you ferret the arrangement out. Measuring (for example) between two pins that yield 2K Ohms when others are 1K Ohm likely means that the 2K Ohm stretch is two 1Ks in series.
These normally don't fail on their own so something burned them and may do it again even if replaced.
Aug 14, 2009 | Intel D865PERL Motherboard
Philips 60pp9100d/37 convergence issues
Did you replace the 6.8 ohm 1watt resistors? As that model will usually blow a couple when the ICs fail.
Apr 21, 2009 | Televison & Video
Have a philips magnavox 8p6044 c102
Hmmm... I dont know where to find those CTR Circuit boards I'll post my general post for you about what I know it has links to the manual and some other sites it may help.
how bad is it burned, did some chips go or just the copper circuit board tracers. you can use circuit board wire and solder it from point to point,
I had somewhat of the same problem with my IC board, I had a bad portion of the board where I had to build a new copper routing with circuit wire, the copper burned off when the resistor failed, you may need to do a little Frankenstein work on your board as a last resort... remember use a low 15 watt soldering pencil, use leaded solder, and USE flux!
however with all my work, I got it running but the IC board is still not running perfect. if you decide you cant fix the TV I would love to buy your IC convergence board from you.
GOOD LUCK! hope I helped...
GENERAL POST WITH LINKS BELOW.....
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Problems after new ic chip install
Did you check for open resistors in the convergence circuits? Often that is what happens when the old ICs wear out it will cause a couple resistors to burn open, and they show no outward sign of being bad. Also double check the IC pins connections for solder bridges thats another common problem, I always use a magnifying glass to double check my solder when ever I do convergence or any IC work where the pins are close. But with the streaks youre describing I would think maybe resistors.
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Convergance
You most likely have some resistors that are needing to be replaced its not uncommon for Samsungs ICs to open a couple resistors when the ICs go out and installing new ICs with the old ones being open can cause more of the convergence resistors to burn. Post the model number of you set and I can let you know which resistors you likely need to replace.
Jun 14, 2008 | Televison & Video
Panasonic MODLE PT53TW53G led code flashes 3 times convergence problem
3 blinks is an error code for the convergence ICs being bad. You will have to replace both the convergence ICs they should be STK392-110 for your model. You can get new replacement ICs at the following link with free instalation instructions with pics so you can do the repair yourself. Heres the link.
Jun 05, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 43UUWX10B
The resistors often burn out on that set when the convergence ic's go. The 3.3ohm 1/2watt metal film resistors those are usually the ones that burn out when the ic's go. you have to unsolder one side and lift the leg up out of circuit to check with a ohms meter. You can not check them in circuit make sure you lift a leg up to check or you will not get a correct reading
May 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Toshiba 43HX70 convergence fix - now no video
I think the hardest to solve problems are those I installed!!
Where do we start==no lecture,but I never change a resistor
unless it has changed (in value!) Use a digital meter and check
the value of each resistor.Toshiba is a bit confusing as to values
of each resistor and location in relation to the IC's.Go over your own work first.Check micro fuses in power supply=F851,F852,
etc. Carefully resolder steel jumper wires at board edge,they feed
B+ to convergence amp circuit.Be sure to verify no shorts in pins
of IC's.(use your meter).........T
Oct 25, 2007 | Toshiba 43HX70 43" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
