Question about Motorola Mobility RAZR V3
Part Hi, my V3 needs a new part and I'd like to know where can I find it. It is a "plaque of radio and flex with mylar". I hope I spelled it correct. Have any idea where to look for? Thanks Ana My e-mail address: anamarta@worldnet.att.net
  • 1 more comment
  • Anamarta Aug 21, 2008
    Thanks for your immediately answer but, because I'm not in US right now, I had to take it to a repair place over here (Brazil) and they came out with that part name to be replaced. That was the best I could do to translate the name of the part from Portuguese to English. My cell phone (V3i) is not retaining charge, the display doesn't stay on and I get no signal. It seams that the problem is with the "circuit RF'' (if that mean anything to you).
    Once again thank you very much for your help.
    Ana
  • Chris Havens
    Chris Havens May 11, 2010
    Yep, that's the keypad flex. Glad you got what you needed.
  • Chris Havens
    In more layman's terms, the V3 is comprised of housing, Motherboard, keypad flex, inner and outer LCD, and upper switch flex.
    I repair cellphones full time. If you can give me some symptoms of what you're phone is doing (or not doing) I should be able to tell you exactly where to get what you need. The tricky part is not only knowing what to ask for, but how to ask for it. Key terms and such.
    Is the left hinge loose with no top display?
Dear Sirs:
Thank you for your help. I found an online site with a phone number that I've called and already got the part. (keyboard mylar with flex cable).
I appreciate your quick answer.
Take care,
Ana
Posted on Aug 22, 2008
    Brigadier General:
  • 7,752 Answers
Fixing those problems would be more that what you paid for the phone so you should just purchased a new one.
My phone's keypad just lights up for few second the moment i turn it on then turns off again without a light on the screen .can you help me fix this problem?my phone is a razr v3 model.
Hi,when a Razor v3 has a light issues isuaully caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and the light.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Aug 17, 2011 | Motorola Mobility RAZR V3
MY PANEL HEATER IS CRACKED. IT STILL WORKS. CAN I FIX IT.
If you're referring to one of the ceramic plaques in an infrared heater? Yes, the plaque(s) can be replaced. However, the heater should not be used until the plaque(s) is replaced.
Without knowing what Brand heater you have and the correct Model Number, I have no way to tell you were to find the plaque you need.
Jul 08, 2011 | General Heating & Cooling
I have no display but can hear the tone when I switch it on?
Flex problem
Hi,no display and cell phones still functions for Motorola phones are usually caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
Hope it helps.
Jun 17, 2011 | Motorola Mobility RAZR V3
Phone turns on and off but the screen is white so I cannot read it?
Hi,white screen for Motorola phones are usually caused by the flex of the phone.
Hope it helps.
Thanks for using fixa
Jan 17, 2011 | Motorola Mobility RAZR V3
My motorola razor v3 has a white screen?
Hi, White screen on motorola razor phones can be caused by either the LCD or the flex of the screen.
First, you will need to check for the flex by replacing the flex of the phone. the flex controls the display of the phone and the keys on the keypads of the phone.
The LCD also can cause a white screen display. After replacing the flex and if it's still has white display,you will need to replace the screen.
Have a nice day.
Sep 16, 2010 | Motorola Mobility RAZR V3
I dropped the phone and now the screen is white. I can't read it. However, the phone still functions correctly.
its a flex problem. The flex that connects the phone main board to the screen must had been disconnected or cut when the phone dropped.
So you have to loose the phone to know the status of the flex. If cut you need to get another flex and replace it, but if removed, connect it back.
Take care.
Jan 03, 2010 | Motorola Mobility RAZR V3
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
RAZR V3 FLEX
you need to take the phone to a mobile service center to have them reflash the flex file into your mobile.
May 01, 2008 | Motorola Mobility RAZR V3
Unlocked RAZR V3 needs new firmware?
if u hav a usb cable u can do it urself... go to this site n sign up n ur half way there... http://www.modmymoto.com/forums/downloads.php
u can dwnload a program called rds lite by searching for it on google. after u hav that software, visit the above site n download firm ware files for r374...... razr. or jus click this link n it will take u to the r374 section where u hav various files to choose from like different language packs n firmware (monsterpacks) http://www.modmymoto.com/forums/downloads.php?do=cat&id=46
good luck
Nov 30, 2007 | Motorola Mobility RAZR V3
Keypad Razr V3C
you will have to search online for that or try www.motodev.com and see if this site helps you.
Sep 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
