Question about Comdial 8324S-PT Corded Phone
How to turn off special features?
Some how my boss has enabled the headset feature and I need to turn it off. I have looked at the manual over and over and can't find the solution. Can you help me?
You can program a button as a HDST (headset) that will toggle this feature on and off.
Posted on Sep 12, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
Can't enable cc on my vizio
it might be because the box has this feature also and it is enabled there
Mar 26, 2012 | Televison & Video
How do i turn on bluetooth feature on my rumor 2
    • 1 Turn on the Bluetooth-enabled device and enable it to be in "Discovery" mode. Check the owner's manual of the device to learn how to put it in "Discovery" mode.
    • 2 Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
    • 3 Press " * " to access the settings menu.
    • 4 Press "1" for the Connections menu.
    • 5 Press "2" for the Bluetooth menu then press "1." Press "Yes" when prompted to turn on the Bluetooth feature. A list of available devices appears in the menu.
    • 6 Highlight the listed device, which should be showing.
    • 7 Click "Ok."
    • 8 Enter the passkey provided in the owner's manual of the Bluetooth device. The standard passkey is "0000." The Rumor2 is now paired with the Bluetooth device.
    • 9 Press the "Call" key on the phone or the "Call" button on the Bluetooth device to answer calls through a Bluetooth headset while paired.
Mar 01, 2012 | LG Rumor 2 Cell Phone
How do i make a hands free call on my head set i have a plantronics explorer 200 series?
To use Voice Dialing:
With the headset on, press the call controlbutton for 2 seconds to activate the voice dialling.
NOTE To use voice-activated dialling, the voice-dialling feature must be enabled on your phone. See your Bluetooth Phone Manual for instructions.
Good luck from Headsets Direct!
Aug 22, 2011 | Plantronics Explorer 240 Bluetooth Headset
Does Visio TV, Model No. M320NV, Ser. No. LAQKGYAL 3200084, have a feature enabling the user to turn it on and off at set times. We need a User Manual. Thanks
Here's a link for the manual http://vizio.com/documents/downloads/hdtv/L32/Manual.pdf
As for a scheduler there is none in the tv only a sleep timer which has to be manually set every time. You can set it to turn off in 30 minutes increments up to 120 min. This is in the menu under Special Features-Sleep Timer.
Jul 06, 2011 | Vizio L32 32 in. LCD HDTV
How to use a headset for comdial 7260-00 HAC?
I'm guessing you already figured out how to plug it in, so the next thing is to enable it :-)
FEATURE 9# enables FEATURE *9# disables.
The Speaker On Off controls the headset after it's enabled.
Carl
Oct 23, 2010 | Comdial 8324S-PT Corded Phone
We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
To pair another headset to the same base, you must first enable the multi-shift
pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
back of base until the power indicator light flashes.
2. Place a charged headset in charging cradle and red indicator light on base will flash
for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
doing so, press either the "+" or "-" listening volume button for 3 seconds until the
headset talk indicator lights to indicate pairing mode, and goes out after successful
pairing. Repeat steps
Jul 11, 2010 | Plantronics CS70 Wireless Headset
BT250v vibrating after picking up the call
Check Jabra website for manual.
It is a simple hold volumne button up or down when switching on or off to disable /enable it
Apr 21, 2008 | Jabra BT250 Consumer Headset
Jabra Vibrate Feature
from the manual at http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Call vibrate*
• Call vibrate is automatically activated when you turn on your headset.
• To disable the call vibrate feature, press the answer/end button and
press the volume down (-) button at the same time.
• To reactivate the call vibrate feature, press the answer/end button and
press the volume up (+) button at the same time.
Dec 19, 2007 | Jabra BT350 Bluetooth Headset Headset
Comdial 8324S-PT Corded Phone Logo
305 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
