Question about PC Chips M810DLU (M810DLUV75C) Motherboard
Is the AMD M810D v 7.5e a model number ?
Or should I look for something else?
Additional information: before I tried to install the memory chip on the machine with the problem, I tried it on my other machine and it worked fine (the other mache also has some type of AMD mother board, but a different one). At least the chip itself wasn't damaged.
But now even the old memory doesn't make a difference. Thank you.
  • nk08 Aug 25, 2008
    Well, I tried to unplug the cables and start again, remove all memory and start again and put old memoty back and start again. The picture still the same: fan works, but no "beep".
    Is it a good possibility, that my motherboard instantly died?
    Before the story started I had the "CMOS battery low" message on almost every boot.
    Currently I need to make a decision - consider the patient dead or alive. Does it look dead for you or there are a trick ot two that I can try to revive it?
    Thank you!
  • Anonymous Sep 27, 2008
    el pc no tiene sonido
Posted on Aug 28, 2008
  • 236 Answers
Well.. This one is a little wierd.. Have you made sure that all the connections from the power supply, and all the connections from and to any peripherals (HDD/CD ROM/etc...) are connected properly, and that all components are seated correctly in thier spots?
Sounds like something is not connected or loose...
also, putting back the old ram and the old battery (at the same time), is the issue the same?
Posted on Aug 22, 2008
  • 1 more comment
  • Dave MacPhee
    Dave MacPhee Aug 29, 2008
    well, try to use the same configuration and components(including PSU and HDD's) with the other motherboard that you know works and test it. If everything works ok, then put it back in the old one again. If once again you get a failure, I would say it is safe to assume your mobo is in bad shape....
  • Dave MacPhee
    To GUEST:
    What driver to you need? Chipset? Audio?
  • Dave MacPhee
    Dave MacPhee Sep 03, 2008
    Perhaps you could do a quick check on the MOBO to see if there are bad capacitors, as sometimes this can cause havoc.
    If so, you can either replace them or you need a new mobo.
Driver m810d pcchips
What's the problem? We need a bit more information than just "I'm having a problem". Please be specific about what is happening and what you're trying to fix.
Oct 16, 2013 | AMD K7- 810DLM8+ Motherboard (Ver 7.5C)...
AMD Athlon XP 3200+
Part number - AXDA3200DKV4E
Front Side Bus (FSB) = 400MegaHertz (400MHz)
Multiplier = 11x
Voltage = 1.65 Volts (DC)
Running at maximum potential it can use up to 76.8 Watts of power.
Thermal Design Point. Or Thermal Design Power. Whichever you prefer)
Have no idea, the gentleman didn't state the manufacturer name, and model number.
Have no idea of what the motherboard chipset is, alone from knowing what the Northbridge chip is; and whether it will support said CPU.
For additional questions please post in a Comment.
Mar 13, 2013 | Computers & Internet
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
K7SV266AD Can I use 266Mhz athalon processor with this board, book says 100/133 FSB. If so what processors? Thanks
The Syntax K7SV266AD motherboard uses a VIA motherboard chipset.
It uses a VIA KT266A for the Northbridge, and a VIA VT8235 for the Southbridge.
About the motherboard chipset;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
High-speed graphics is AGP or PCI-Express
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
(Integrated Graphics is also referred to as OnBoard graphics.
ON the motherBOARD. The graphics chipset is soldered directly to the motherboard, and not to a graphics adapter card. {Graphics card}
The graphics chipset is a GPU.
Graphics Processing Unit,
The Southbridge chip handles the slower capabilities of the computer.
It handles the IDE, and SATA capabilities of the computer.
It also handles the USB ports, Ethernet, and Audio, plus anything connected to a PCI slot, and Integrated Graphics, to list a few examples.
Motherboard Diagram,
[For further information you may wish to search on Wikipedia,
A) Northbridge (computing)
B) Southbridge (computing)
C) Bus
D) PCI Local Bus
E) AGP (Accelerated Graphics Port)
F) PCI Express
G) Front Side Bus ]
Looking at the motherboard with the Processor to the top, and Ram Memory to the right, the VIA KT266A northbridge chip is below the Processor.
The aluminum finned Heatsink covers it.
The VIA VT8235 southbridge chip is down towards the lower right corner.
Looking at the specs for the VIA KT266A chip we can see,
1) It supports either DDR Sdram ram memory at 200MegaHertz, or 266MHz.
PC-1600 or PC-2100, respectively.
(DDR Sdram is clocked twice. Therefore the 133MHz Front Side Bus {FSB} support will handle 266MHz ram memory)
2) The Maximum ram memory it will support is 4GB. If you have the motherboard manual, you will know what the maximum amount of Ram Memory is, that the motherboard will support.
3) Will support Processors with either a 100MHz, or 133MHz FSB. (Front Side Bus)
AMD processors are 'Double-pumped'.
The VIA VT266A chip will handle AMD processors with up to a 266MHz FSB.
It will handle AMD Athlon, or AthlonXP, or Duron processors, with a maximum FSB of 266MHz.
The best processor will be an AMD AthlonXP with a 266MHz FSB, that fits in a Socket A (Socket 462) processor socket.
Watch the Voltage used. Look up the AMD processor you have installed now, and see what voltage range it uses. The new processor must use voltage in this range also.
For additional questions please post in a Comment. (Upper right of your page)
Jul 04, 2011 | Syntax Computers & Internet
I want to know how many RAM memories(in GB) can reach the motherboard M810D
You can calculate it yourself.
a = the number of simm slots
b= the maxium value of ram chip the moher board allows
there for the total is a * b ram memory
eg 2 slots , 512mb max memory chip size = 1024mb memory max
Aug 17, 2010 | Computers & Internet
I want to try to Instal a second AMD Microprocessor
sorry not posible theres only one slot on the motherboard for the chip.
apart from that theres a heat issue and power supply and .....
if you manage to do the upgarde there will be no space to allow proper cooling,
two chips will definately need cooling .
New body might be required to accomodate all the extra parts too,
Cheers Misterdj
Apr 09, 2010 | AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA)...
BOOT falilure after RAM installation
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Aug 20, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
M810d V7.5 motherboard drivers
For the PCchips M810DLU I had to go to the Taiwan site and it lists a PCB version 7.5a, not the simplier 7.5, but I'm fairly certain that the video, lan, and audio drivers will be the pretty much the same. But I must add that trying to update the bios ( while it may be possible ) may also cause issues, so be careful and read all pertinent information before attempting any bios updates.
Information here
Aug 10, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
PC Chips M810DLU (M810DLUV75C) Motherboard Logo
1,023 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
