Question about HP Pavilion a305w (DM181AR) PC Desktop
My bightnees bar wont go off
My brightness bar will not go of on my screen my buttons on my screen will not shut it off unless i hold it in then when i let it go the brightness bar comes back up. can i please get some help
    Genius:
  • 1,847 Answers
This is some issue with your monitor and nothing to do with the computer.
try factory setting and still not go the montor have to repaired in person by a tech.
Posted on Oct 14, 2008
SOURCE:
Cant log into windows. screen black
If you have a function button try holding it down and pressing F2, possibly the screen has been accidentally switched off.
Apr 15, 2013 | HP Compaq Presario V2000 Notebook
My gateway 450rog computer screen wont come on after i press the power button why
Make sure the machine has power.
The battery might be dead, so connect your notebook to the AC power adapter and plug the adapter into a working AC outlet.
If you have a power strip or surge protector, make sure it is on.
If you are having trouble with battery power, recharge it if it has been fully discharged or replace it if necessary.
Check to make sure the computer is not in "sleep" or "hibernate" mode.
Press a key or the touchpad and wait for it to respond.
Try pressing the power button.
Make sure that you fully engage the power button.
You should press and hold the button for at least half a second but no more than three seconds for the machine to power on.
Adjust the screen's display brightness because it may be too dark. Press and hold the "FN" key and press the key with the icon to increase brightness.
This icon looks like an "up" arrow and a picture of the sun.
hope this helps
Sep 13, 2012 | Gateway 450ROG Notebook
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
Palm z22. wont startup without holding the up arrow key and doing a soft reset. Then Task icon wont load and some of the other applications wont load
Try doing a hard reset. Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
Here are the directions:
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
The progress bar On some devices, you may see a Palm or palmOne logo and a progress bar first. Do not release the Power button until the second, circular Palm Powered logo appears. From there follow the on screen directions and then do a HotSync. Best wishes
Oct 25, 2009 | Palm Z22 Handheld
The picture is to bright
problem in high voltage area, consult an expert
Jun 02, 2009 | Emerson EWF2704 TV
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
Wont turn on
this guy needs to be barred for life!!!
Jan 10, 2008 | Coby MP-C7085 MP3 Player
if you are a tech open the tv and turn down the brightness from off the flyback screen adjustment if that does not work then the flyback will have to be replaced.it is defected.good luck
Apr 19, 2007 | Emerson EWF2703 27" TV
HP Pavilion a305w (DM181AR) PC Desktop Logo
115 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
