replace the starting pull cord
Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below Craftsman 17 25cc Weedwacker
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
Align the arrows under the bump feed, push in on bump knob, unscrew in counter clockwise direction, remove spool. Wind string in direction arrows advise on the spool, reassemble. You will be back to weedwacking asap.
I hope you dident screw it up, a person can realy mess up the platability in a hurry if you dont know what your doing. Lets see if we can get you on a good track .What your looking at is your tali pice. that whitch holds 6 saddels the saddels have horizontal screws. Hex you need a very little alan wrench. they normaly come with a new Ax.string heights are 2.00 at the 5.th and 1.5 on the 1first. use a line of sight to see that strings are in a good line. Never Never screw the vertacal screws with springs. Thisis your intonation. if you mess this up you lose the playabilithy of you gtr. ps Guitars dont come with manuals. check with your local music stoer. find a musician thats will ing to give some hands on tips.
