I have a MATSUI PF-A703 digital photo frame. Supposed to to able to put memory stick with photos stored on it into the usb connection and view the photos but it displays only 1 photo(the same photo) everytime it loads and nothing else happens
IBeMad
  • 85 Answers
SOURCE: I have a digital photo
It depends on if the supplier has an upgrade for it. What brand is it?
Posted on Mar 16, 2008
Arungeek
  • 10 Answers
SOURCE: I have just purchased a
Sure....i think u can find the option in the digital photo frame.....it may like repeat or the symbol...just check it out and have fun
Posted on Mar 17, 2008
Agent Ken
  • 250 Answers
SOURCE: How many photos can be
Hello Keith-ham,
The number of pictures that a digital photo frame can hold is dependent upon the amount of internal memory that the frame has and the file size of the pictures.
Many digital photo frames have 128 MB of internal memory. Assuming an average file size of 3-4 MB, such a frame could hold around 35-40 images.
Some frames also allow you to plug in an SD memory card from your camera, so the amount of storage space the the frame has can be greatly expanded.
Best Regards
Agent Ken
Go Ahead. Use Us.
Posted on Apr 14, 2008
hulk god
  • 36 Answers
SOURCE: photos from pc to sd
The easiest way to do this would be to buy a card reader for you PC. You can buy an external one that plugs into the USB port.
Another way is to used a computer with a SD reader and upload it into a flash drive. Once you have the flash drive, you can upload the pictures using your flash drive into the frame.
Posted on Aug 08, 2008
SOURCE: I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Posted on Jan 02, 2009
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
Hello, I have the following digital frame. Unfortunately, I don't have the instructions. Mustek Model # PF-A702BM. I uploaded the photos to my frame but unfortunately didn't copy them to my computer...
If the photos are on an external memory card you should be able to put that into your computer and retrieve your photos that way. If this is not an option because the photos are actualy saved to the digital photo frame then you should be able to connect the photo frame to your computer using a USB cable and then copy the photos to your computer. I am not particularly familiar withthe product but i hope this helps
Jan 09, 2011 | Cameras
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
How to scan photos from a scanner on to a memory stick I want to transfer old photos on to a memory stick to use with my digital photo frame
First, make sure the scanner is connected to your PC via USB cable.
Hopefully the scanner software is already installed on your PC, your scanning should automatically show up on your PC screen.
From there, save to Memory Stick and you should be able to view it on your digital photo frame.
What scanner model and brand do you have by the way?
Jan 30, 2010 | Canon MX300 Office All-In-One Printer
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Digital photo frame
hi, got the same problem, tried pics at different res, compressions, from different cameras and programs...still no luck
Dec 22, 2007 | Baby Gear
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
