Question about Vacuums
I have bought a dysonmotorhead and when i switch it on the light on the head is green when i start to hoover it goes red can you tell me why
    Master:
  • 623 Answers
Check it for loose connections...clean evrything
Posted on Aug 21, 2008
    Master:
  • 848 Answers
There is some problem in the inner connection the power supply is not distributed properly to the inner components ......
  • Vacuums Master
  • 19,396 Answers
Check that the bag is not broken or full, check that the hoover is not obstructed on the inside.
  • Ginko
    Ginko Aug 21, 2008
    Check that is not something entangled around brushbar or inside the vacuum hose, this is a common cause for red light on the Dyson Motorhead.
    If you do not find anything wrong, it can be something broken in hose assembly, this is normally covered if your Dyson it is still under the one year factory guaranty.
    You find a phone number to get service on your owner manual.
HOOVER Freespace TFG 5123 - Red Light?
Check the entire flow path from intake to bag. You may find it is clogged.
Dec 12, 2013 | Vacuums
My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Red light stays on
It sounds like the plates inside the vacuum that detect the dirt have become dirty. I don't remember where they are, but I think they're accessible if you remove a certain hose. Again, I don't know which hose it is.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
RED LIGHT INDICATOR
You either have a problem with the sensor or the circuit board. Most times it is with the sensor. Take the hose off, look inside of the part that the hose hooks to, you will see a disc, it may be clogged with dirt, try cleaning it, if that doesn't work, then the sensor may be bad.
Dec 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover vacuum U6655-900
It is called the dirt sensor, you can try to re-attach the wires if there is enough there to do that. Otherwise you would have to replace the sensor, it may come with the duct(#21), the other end goes to the circuit board(#36) where the head light is. It tells you if there is a clog, when the light turns to red.
Feb 29, 2008 | Vacuums
Hoover Wind Tunnel 2 won't stay on
Possible that the switch is bad, part #40309033, take the handle off, then the tool compartment, then you can get to the switch, almost bet that one of the contacts is bad.
Feb 20, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Oct 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Sep 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
HOOVER SAVVY
I had the same problem. Took it in and the repair shop they said it was the switch. It was an $18 switch and $30 labor. Switch was a red on/off button with 2 wire leads and caps to screw on for connection. If you can wire a ceiling fan then this looks about the same difficulty.
Feb 17, 2007 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
