Question about Star Logic 17" LCD Monitor
I am tryin to coonest my HP pavilion dv2000 to my logic 32" lcd tv. i ane got thr vga cable wired up but cannot get any joy out of it yet. please help me
  • 558 Answers
The TV needs to be put into VGA PC input mode for video selection like channel vid 1 or vid 2 there should be "PC input"
Posted on Mar 21, 2009
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
Hp pavillon dv2000 line on computer
Find out if the problem is the graphics chipset, or the LCD screen.
Laptop OFF, monitor OFF, plug a VGA monitor into the VGA port on the Pavilion dv2000 series of Notebook PC.
1) The VGA port is on the back of the laptop. Looking at the back of the laptop, it is the second port from the Left.
Example of a VGA connector, (On laptop it is a Port), and a VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
The VGA monitor can be a CRT, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
The VGA monitor will now just be referred to as External Monitor.
Monitor plugged into the laptop, turn the monitor on. Wait a few minutes if it is a CRT monitor.
Turn the laptop on.
The external monitor should automatically show the graphics of the laptop.
If not press, and hold down on the Fn key, (Bottom row of Keyboard, second key from the Left. The Windows key is to the right of it ), AND at the same time tap once on the F4 key.
If graphics do Not show up on the external monitor, press, and hold down on the Fn key, and tap the F4 key once more.
[ Your laptop has at least three functions for this Hotkey. (F4)
{Also known as Display Toggle-Over key}
1) Laptop internal display Only.
2) Laptop internal display, and external display. (In this case, a monitor. A Projector can be connected here also)
3) External (VGA) monitor Only ]
A) Does the external monitor have this line going through it also?
Yes? Problem is with graphics chipset.
B) No? Problem is with screen Inverter, or LCD screen.
Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is a small circuit board that converts the electricity from the laptop, for the Backlight, and LCD screen.
(Too broad a statement. There are some laptops that their LCD screen, does not receive power through the Inverter. Their power is derived from the Video Cable only )
90 PERCENT of the time the fault is the Inverter
This is an example of a screen inverter, for an HP Pavilion dv2000 series of Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&cPath=91_96&products_id=200
Click on the image to enlarge. (Size is approximately 1/2 inch tall, by 4 inches long)
Make a mental note of the price. This is an average price. You may also find a better price.
This is an example of a replacement LCD screen,
http://www.laptopscreen.com/English/model/HP-Compaq/PAVILION~DV2000/
A1) Without a sensitive multimeter, (Read expensive), you do not have a way to test the Inverter.
IMHO I would replace the screen Inverter, and see if this repairs the problem.
If it does not, then an LCD screen replacement is next.
B1) If the line is on the external monitor, you have a graphics chipset problem.
With most laptops a motherboard replacement is the easiest option, however it is the MOST expensive option.
It has been found that the HP Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, have a graphics chipset problem.
It isn't the graphics chipset, per se, it is the mounting of the graphics chipset to the motherboard, AND the inefficient cooling for the graphics chipset.
Primer:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The graphics chipset is the GPU. Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
Use GPU-Z to find out what exact GPU your laptop has.
I do know that it uses Intel GMA 950 for graphics, which is usually paired up with one of Intel's Core2 mobile chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core.2FCore_2_mobile_chipsets
The graphics chipset is mounted to the motherboard with a BGA surface mount.
Ball Grid Array.
To explain a BGA surface mount, let me compare it to the Intel Pentium 4 processors, that used a Socket 478 processor socket.
The bottom of the Processor has contact pins. 478 of them.
The Socket 478 processor socket has 478 socket holes.
With a BGA surface mount, there are no contact pins, and no socket holes.
Solder Balls on the bottom of the graphics chipset, take the place of the contact pins.
Copper Pads on the motherboard take the place of the socket holes.
When installed by the factory, the graphics chipset is set into place on the motherboard, so that the Solder Balls are lined up with the Copper Pads.
The chipset is heated to a specific temperature, for a specified length, and the Solder Balls melt.
The solders the chipset to the Copper Pads. Solders it to the motherboard.
IF, the graphics chipset repeatedly overheats, the solder connections are partially melted, and this makes a bad contact. (Contacts)
A video I found that explains the above in more depth,
http://www.youtube.com/watch?v=bnkQNmKauEc&feature=pyv&ad=5823851286&kw=DV2000
(NOT advertising for this guy, just inserted for the information, and video )
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 10, 2011 | Compaq Presario M2000 Notebook
I have a vga cable hooked to my sansui tv and to my laptop, but the tv just says "no signal". What do i need to do?
you may need to change the resolution of the desktop it may not be correct for the input that the tv needs. also look for any buttons on the laptop that will switch the video over to the VGA output. i suggest tryin around 600X800 and see if it will show up. good luck
Jan 07, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Dv2000 no backlights
change the neon bulb inside the lcd will light it up again.
note : the neon bulb's cables color Pink and white
Dec 15, 2009 | HP Pavilion dv9000z Notebook
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
The Laptop Powerup no display in dv2000
Since you can view the laptop's output through VGA, it indicates that the issue lies with the laptop's LCD. As u mentioned, firstly the LCD become dull, and now it completely dead, suggest that the internal flat ribbon cables that connect the LCD to the motherboard of your laptop may have been damaged. This could happen sometimes after extensive use. Please get it checked with authourised technician. Do not experiemnt further, as this could make the situation worse. Cheers..
Jun 22, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Unable to connect to samsung tv as monitor for hp laptop
Hi there
DSUB is VGA, has your TV got a VGA port on the back? if so and you know what the source the channel is then you will need a male to male VGA lead and a mini stereo jack to left and right male phono jacks for the audio, the DSUB or VGA does not carry audio through it.
Good luck and thanks for using Fixya!!
Feb 12, 2009 | HP Pavilion dv2000t Notebook
Connect HP Pavilion dv2000 laptop to Panasonic Viera 42'' plasma
If you get your wallpaper to show on your TV, then you should be almost there.
  • Try to right-click somewhere in the desktop, choose "Properties" and go to the Settings tab. (Now you should be able to see both monitors.)
  • Click on the "Identify" tab to see which one is your TV.
  • See if "Extend my Windows Desktop onto this monitor" is checked.
  • Try to find a resolution that works with your TV by changing the values for the screen resolution.
Jan 03, 2009 | HP Pavilion dv2000t Notebook
My monitor is not working hp pavilion dv2000
hook a vga monitor to the external port on the lappy use function keys to see if it is putting out a video signal if not mobo / video card may be bad if it is cable / lcd maybe bad or could be a virus
Oct 24, 2008 | HP 417035-001 - HP Pavilion dv2000 Series...
Star Logic 17" LCD Monitor Logo
144 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
