Question about Acer Computers & Internet
How to add memory module to Acer 3003WLCi notebook
    Master:
  • 397 Answers
On the bottom of the laptop you should see one or two screwed down covers, one usually covers the harddrive and the other will cover the memory and sometimes the wireless card slots.
Use the memory configuration tool at http://www.crucial.com to make sure you buy the right memory card for you machine.
Posted on Aug 21, 2008
How do you turn on the wifi on an acer 3003wlci
Check the BIOS settings to see if the wireless card installed and enabled.
If it is enabled then install the wireless driver.
Download the wireless and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Mar 03, 2012 | Acer Aspire 3003WLCi Notebook
My Acer Aspire 3003wlci was working, I restarted it and now the power light flashes yellow. I get no video. I have tried removing the battery, powering the unit without the battery, swapping the hard...
try this.
take out battery, unplug power cord.
hold power button for 60 - 90 seconds.
insert battery and power cord and then power on. hopefully works. let me know how you get on?
Oct 26, 2011 | Acer Aspire 3003WLCi Notebook
Can I remove ram from acer aspire 3003wlci to add to toshiba satellite p205d-s7454. The acer is pc-2700 and Toshiba is Pc2-5300 200 pin DDR2. Is sticking a USB 1gb readyboost the same as installling 1gb?
To answer your question, no. Those RAM types are not compatible as they are a full generation apart in terms of a RAM lifecycle.
And to answer your question about Readyboost, no. Installing a 1gb flash drive to use with readyboost isn't the same as installing an extra 1gb of internal system memory. It essentially allows Windows to use the newly added flash drive as a system cache. See more information on Readyboost here.
Thanks, and have a great day!
Oct 03, 2011 | Toshiba Satellite P205D-S7454 Notebook
How do I change font size
Sorry which type of Operating System used with Acer Aspire 3003WLCi Laptop PC Notebook
Jul 11, 2011 | Acer Aspire 3003WLCi Laptop...
I would like to add memory to my acer 5315 notebook. I have taken the panel off the back, but I don't know where to put the new RAM in. I can only find how to replace memory, not to add more.
The ram location is right where you are looking. There are two memory slots available for ram. They are staggered one on top of the other. Release the side pins and the module will pop up at a 45 degree angle . Pull the module out in the direction and replace at that angle, then push the module down in place. You may only have one memory slot filled at this time, Therefore there would be an empty slot to fill.
Jun 01, 2010 | Acer Aspire 5315 Notebook
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
I have an acer aspire 3003WLCi pc notebook and it
reinstall the computer again
swipe it and start again
if you have eRecovery installed on your machine then reinstalling should be about 45 min
At the very least you will have a usable machine straight away
Hope youve already saved your important stuff
Mar 23, 2010 | Acer Aspire 3003WLCi Notebook
How do I replace the power connector on an Acer Aspire 3003WLCi?
Take the computer to a qualified & certified connection;
this is not a "field-replaceable part".
Sep 17, 2009 | Acer Aspire 3003WLCi Notebook
Trying to add memory
Here is a link that gives step by step with pictures. Be sure to properly ground yourself by either wearing a wrist strap or touching metal surface when handling the module
http://www.crunchgear.com/2008/08/28/how-to-add-ram-to-the-acer-aspire-one-netbook/
Feb 27, 2009 | Acer Aspire One AOA150-1029 Notebook PC
No sound
pls take out the battery and ac supply and then press the power on button on notebook for like 5 sec to discharge any energy inside then after like 2 min re seat battery and ac supply and then see if ur sound works otherwise
update ur audio drivers and let me know from here u will find it go in drivers folder if u are using XP or vista folder if u use vista
ftp://ftp.support.acer-euro.com/notebook/aspire_3000/
and let me know abt the results
pls rate FIXYA if ur problem solved
Jan 11, 2009 | Acer Aspire 3003WLCi Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
