Question about Pentax Optio S4 Digital Camera
No LCD display
I turn on the camera and the lens come out, but the LCD screen does not have any display until much longer, say, 10 mins later, or, like now, never comes on anymore. but when I press the display button when the camera is switched off, the LCD screen works.... I guess this is a camera problem and not the LCD problem....
  • 2,071 Answers
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 21, 2008
I have Panasonic Lumix DMC TZ3 camera and it suddenly stoped working when i switch on the lcd is black first i thought my lcd has problem but i can see images from my memory card very well only when i go...
Hello
First, if the camera turns on and the lens extends properly, toggle your "display" button until the screen image returns. (you can turn the display off via this button and is most likely the issue).
Otherwise, it would indicate a greater issue that would require the camera to be sent in for service.
Mar 10, 2011 | Cameras
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
Dec 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I have no LCD screen when my E300 is turned on, it stays blank until I take a shot, the LCD screen shows this shot for a couple of seconds and then blanks again.I can't seem to find the problem in the...
Have you tried pressing the 'INFO' button? This little button will toggle between camera info on display/no info on display (when the display isn't in use to display pictures).
Oct 19, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Turns off right away
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
rate me!!!
May 24, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Diplay turning white on mju 700...
Hi
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
Good luck from Darntoothysam com
Thomas
May 01, 2008 | Olympus Stylus 700 / 700 Digital Camera
White Screen + Stuck Lens
Turn the camara off and lightly tap on the front about 10 times the white screen will go away just tried it on mine a couple of min ago and it worked. don;t know about lens
Feb 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Pentax Optio S4 Digital Camera Logo
149 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
