Question about Canon DR-9080C Path-Through Scanner
The documents are scanned but dont appear on later inspection, or if they do they are just a horizontal line across the middle
We have about 20 of these scanners and use Capture Perfect 3.0 on all our machines. Sometimes capture perfect will freeze white along the "file" toolbar whilst scanning documents. The Feed tray will be stuck at the top while this crashes and the documents go through without jamming but when inspecting the work, the images that went through are blank or have a thin black horizontal line on them. We have tried different scanners and different PC's (ones which we know work) but the same people keep getting the same problem. Sometimes the software doesnt crash but the documents still are not correct when scanned. They often occur after a paper-jam if that helps.
Any information would be greatly appreciated.
Many thanks,
David Cove [email protected]
Try the version that came with the scanner Mine Was 3.0.1250.336 and is more stable than the new one.
Posted on Feb 06, 2009
  • 490 Answers
Try reinstalling the driver software. If the problem still persists, run scandisk or reinstall OS.
S. Mohan
Posted on Nov 08, 2008
SOURCE:
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Balancer repair
Normally horizontal line [a thin vertical line across the center of the screen] fault with CRT based TVs is the fault with its vertical scan output section circuit. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 11, 2016 | Televison & Video
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
Horizontal lines on photocopies made but no lines appear when document document is printed.
Hi there, As it sounds its a dirty scanning glass. Open the top of the scanner so that you can see the scanning glass.. If your standing in front of it you will see on the left hand side a strip of thinner glass.. Take a damp cloth (better cloth with spirits/surgical alcohol) and clean the both the small and the large scanning glass. These lines normally cause if the glass is dirty. Especially if your using the document Feeder. As a lot of time wet ink or typex or correction fluid gets stuck on glass which will cause these lines.
Hope it helps
Regards,
Jul 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Lines across scan
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Lines appearing in scanned images
it is due to following reasons 1. dust on lense 2. connector problem 3. laser lense gone 4. missalingment
Sep 28, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Feb 13, 2007 | Visioneer Strobe XP 200 Path-Through...
Canon DR-9080C Path-Through Scanner Logo
332 people viewed this question
Clive
Clive
old marine
old marine
Ekse
