Question about Braun Tassimo Espresso Machine/Coffee Maker
Button Hi, my tassimo stopped working and after some investigation I have discovered the main button is not connecting with the button on the circuit board. Looking at the main button it looks damaged at the pointy end. Is it possible to buy a new button? Regards Stuart (UK)
  • mow18mow18 Sep 12, 2008
    Had a better idea, I chucked it in the bin!
Buy a kettle
Posted on Sep 07, 2008
I need to no how to work bosch tassimo
You need to add water to the reservoir. Turn on the unit with the on button. Open up the top to insert the Tassimo coffee discs. Then press the large lighted button. Coffee will dispense into your mug.
Mar 13, 2016 | Bosch Washing Machines
I HAVE REPLACED THE POWER BOARD. STILL WONT COME ON. CHECKED THE CIRCUITS. YES POWER IS TO THE BOARD. COULD IT BE THE SIGNAL BOARD?
Hi Pam,
For a TV to come on, the power board has to send 'stand by or SB5V or 3.5V ' to the main board. On your pressing power on button on remote control, the main board sends power on command to the power board which in turn produces all the necessary supplies to run the TV. If the main board does not respond to your TV on command, the TV will not work. So It is not the power board which is responsible for not powering on of a TV every time. A voltage investigation before changing boards is always helpful. I hope it helps.
Aug 14, 2015 | Televison & Video
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Remote often fails to unlock the doors on my 2006 Buick Lacrosse. Seems to work better from farther away.
  • I HAVE HAD SIMILAR ISSUES WITH THE KEY FOB, OR "REMOTE" . UPON FURTHER INVESTIGATION, I OPENED UP THE REMOTE AND FOUND THAT THE THIN, SHINY METAL FRAME ENCLOSING AND CRADLING THE COIN-LIKE BATTERY (CR2025) HAD BEEN SEPARATED FROM THE SOLDER POINTS ON THE SILICON CHIP.
  • I ALSO DISCOVERED THAT ON THE REVERSE SIDE OF THE CHIP (BUTTONS AND RUBBER COVERING SIDE) THAT THERE WAS DIRT, DEBRIS, AND OTHER GUNK WHICH WILL DEFINITELY SHORT CIRCUIT, CAUSING YOUR REMOTE'S BATTERY TO BE DISCHARGED OR MISFIRE. THIS IS BEST OBSERVED WHEN YOU EXPERIENCE A "STICKY" BUTTON EFFECT ONCE THE "LOCK" BUTTON IS DEPRESSED ONCE, BUT THE CAR FEED BACK SUGGESTS 2 PUSHES OF THE REMOTE WERE DETECTED. ANOTHER EXAMPLE: I COULD HAVE SWORN I PUSHED "UNLOCK" TWICE (UNLOCKING REAR DOORS )ON THE FOB/REMOTE BUT ONCE I GET TO THE CAR, DOOR IS STILL LOCKED! WTF.
SOLUTION:
KEEP KEY FOB / REMOTE CLEAN, REPAIR/REPLACE BROKEN BATTERY +/- CONNECTIONS IN THE REMOTE, REPLACE LITHIUM BATTERY
Mar 15, 2011 | 2006 Buick LaCrosse
Our tassimo will not stop blinking, all the lights. We have tried cleaning it but that does not work. Where do we send it for repair?
Hey I was having this same problem with blinking and I was shaking the tank trying to get it to engage when my husband, who can fix literally anything, discovered that the magnet in the tank has to engage with the read sensor inside the machine. This magnet is what tells the machine that the water is getting too low. Our magnet gets stuck out of place sometimes. He said it is getting weak and we need to replace it. He used another magnet and held it at the back of the machine beside the tank near the magnet to trick it to engage. It really works! Now, I wonder if Tassimo can send me the perfect size little magnet to replace it. HMMM!
Aug 31, 2010 | Braun Tassimo TA1400
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
No power
How do you know the power button is at fault.
Apr 29, 2008 | Philips Magnavox 27MS343S 27" TV
Tassimo Goes Right From Auto to Standby
I called Tassimo customer service and they helped me solve the problem. The sensors need to be reset
1) unplug machine
2) Before turning on, push and hold the START button
3) Release the START button after the machine is on
4) Insert T-disc and close lid
5) when it goes to AUTO , press START
this fixed my problem
Dec 31, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
313 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
