Question about Panasonic KX-T7453 Corded Phone
KX-T7453 co light will not light when someone is on the phone
When I follow the instruction for one touch dialing and program an extension number. The light is not lighting up when the person is on the phone. The lights are not out, we have tested them. The phone was programmed awhile ago and those that were done still work but when we try to add new ones, they are not
  • Panasonic Master
  • 2,460 Answers
I don't know what instructions you have, but try these.
Press PROGRAM 99 and the button you want to program
Dial 1 plus the extension number and STORE.
Was that what you were doing?
Carl
Posted on Aug 23, 2008
  • Jackie Estevez
    Jackie Estevez Nov 12, 2013
    Thanks, for the help. You hit it right on target.
HOW DO I CHANGE THE GREETING ON A KX-T7453 PANASONIC CORDED PHONE?
The KX-T7453 phone does not have a message function, you may have an associated voicemail on your system. Try dialing (on the intercom) extension 165 if you do not have a voicemail button. Are you trying to change the greeting for your individual phone or the main greeting people hear when they call your company?
This gets a lot more complicated and you should contact your vendor.
Dec 24, 2014 | Panasonic KX-T7453 Corded Phone
How do I store extensions in KX-T7453?
PROGRAM BUTTON
99
PRESS THE BUTTON YOU WANT TO STORE THE EXTENSION ON
EXTENSION NUMBER
AUTO DIAL/STORE BUTTON
Nov 05, 2014 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I have Panasonic kx-T7453 and one of the Outside lines was already connected to a station and while programming a One-Touch dialing ended causing the outside line to be disconnected to this station. How do...
    In a TD system, the lines have 2 digit number 01-12 normally, up to 55 actually. So, if line 1 is missing, press PROGRAM dial 99 press the unprogrammed button and dial 0 01 STORE
    Press PROGRAM or pick up the handset and drop it back down to exit programming.
    Carl
    Apr 21, 2011 | Panasonic KX-T7453 Corded Phone
    If I call an extension and they don't answer how do I program the phone so that I can leave that person a message? I'm using Panasonic KX-T7453 Thanks Chris
    Press the MESSAGE button. It will light the lamp on the receiving station and when they press MESSAGE it will show that you called.
    If you're trying to program "voice mail", then there are specific instructions to setting Call Forward No Answer or just dialing into the VM sytsem and dialing #6 and their extension to leave a direct message.
    Carl
    Dec 01, 2010 | Panasonic KX-T7453 Corded Phone
    HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Carl
    Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
    KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
    Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
    To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
    The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
    Carl
    Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
    It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
    Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
    Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
    Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
    Carl
    Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
    Setting a CO button to flash for a specified number
    I assume that the program sequence that you started with was:
    [Program], 99, [CO-09 Button], 2, [desired phone number], [Store].
    To change it back to CO-09:
    First go back to the phone that needs to be corrected,
    [Program], 99, [CO-09 Button], 0, 09, [Store].
    Jun 23, 2008 | Panasonic KX-T7453 Corded Phone
    Panasonic KX-T7453 Corded Phone Logo
    163 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
