Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark X3470 paper jam
Had cover open problem - solved it with your help!!
now PAPER JAM!!!!!!!!!!! There is NOOOO paper in there.
    Problem Solver:
  • 11 Answers
There is a foreign object of some sort in the paper path which probably caused the jam originally. If you cannot see it looking into the paper slot at the top rear, turn the printer up side down while carefuly holding it shut and shake it vigorously in every direction. It make take many tries but I promise you, thereIS something in there. Go to fixyourownprinter.com for many posts solving this problem.
Qwester1
Posted on Aug 21, 2008
SOURCE:
My pixma mp540 has a paper jam, but i cant even see the paper to remove it and i have opened all available crevices..!!! please help me, its essential i have access to it tomorrow....!!!!! can i open up...
Hello and Welcome to FixYa!
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!
May 13, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Papaer jam
Hello! Welcome to FixYa
Paper jam
To solve it
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
Concerned: Angel Bird
Mar 31, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Clp-510 constantly gives paper jam error, although none exists.
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
To solve it :
If problem still exist then best option to contact Samsung Printers Service Provider, Your problem will be solved,
I hope this solution will be helpful for you
Anymore help, I am here to help
Thanks
Mar 26, 2011 | Samsung CLP-510 Laser Printer
There is no paper jam but its saying paper jam f4100
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
To solve it
If still problem exist then best & final option is to just contact to any HP service provider.
Thanks
Concerned: Uxair Shah
Mar 20, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
My printer is not print it show's paper jam but the paper is not jam
Hello thanks for using Fixya
To solve it
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using Fixya
Feb 25, 2011 | HP DeskJet 3940 InkJet Photo Printer
Indicating (paper jam).No paper present.
Hello thanks for using fixya
To solve it
THANKS & Keep Using fixya
Feb 16, 2011 | Canon PIXMA MP750 All-In-One InkJet...
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
127 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
