Question about Neff Ovens
Neff Oven Fan stalling
Neff double oven U14...
The fan in the main oven intermittently appears to stall and then restarts. It sounds quite loud and final, but it then restarts.
I have removed the element/fan cover and the fan appears to be free.
The cooling fans appear to be working.
the small oven appears to be working.
The thermostat light seems to be functional.
The heating element is working.
Fan was replaced about 4 months ago (genuine Bosch).
SOURCE:
barkencoa
  • 3463 Answers
SOURCE: Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Neff U1421 double oven fan has packed up ?
Yes it is the fan that needs replacing.
It is a fairly straight forward repair, just remember that the nut that holds the fan blade on is a left hand thread, so to undo it, turn
it clockwise, as though you were you were tightening it.
Please leave a fixya rating for my solution.
Thankyou.
Posted on Feb 04, 2009
apart4u
  • 213 Answers
SOURCE: neff circotherm doudle oven main oven fan working
For all Free appliance repair videos visit our VIDEOTUTORIALS1, If the fan motor in the back of the oven is going round and thetemperature light is on (normally little red light), but there is no heat thenyou will probably need a new oven element, these are generally very easy to fitand readily available from our website these can be tested with a electricmeter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then youneed To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
apart4u
  • 213 Answers
SOURCE: Neff 1721 0ven element not working??
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
  • 157 Answers
SOURCE: my Neff U1721 main oven is not heating up - fan is
yes
Posted on May 14, 2010
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
Fan stops intermittently
If you are referring to the main oven fan, then that indicates it is failing.
It will only be a matter of time before it stops altogether.
Only solution is to replace the fan motor.
Please rate my solution.
Thankyou.
Jan 11, 2010 | Neff U1421 Double circotherm Electric Oven
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Aug 15, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
71 people viewed this question
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
Domenico Grillo
Are you a Neff Oven Expert? Answer questions, earn points and help others
