My son recently threw an xbox 360 game bad at my hdtv wharfedale screen, the colour changed and i can't see anything except for white and multicolours also around the dent. Please how do I go about resolving this?
    Genius:
  • 2,920 Answers
You will need to send the tv to a rpair shop..he may have broken the screen on the inside of the tv.
Posted on Aug 21, 2008
My Xbox elite is just over a year old. I have no red rings. Problem is that all games played on the box are now in black & white. There is no colour on my tv screen. There is nothing wrong with the...
Check and recheck and triple check the av/hd cables. If you want to help isolate, try hooking up your xbox 360 to another tv and doesn't matter if it is hdtv or standard to test out. That method will give your answer quick to help isolate the problem. If you have hdtv make sure your adapter has the switch set for hdtv and not standard and then go in the xbox 360 dashboard system settings and see if it shows up for display. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Elite Console
My xbox 360 is from the united kingdom (england) i am in canada, i have bought a power converter to convert voltage, but, the screen is in black and white!!ive plugged everything in as normal!am i doing...
A UK Xbox will work on a uk TV, which uses the PAL colour system. Canada use NTSC so the image is black and white. Can the Xbox be configured for NTSC ?
Dec 30, 2008 | Microsoft Xbox 360 Console
COLOUR
If this has happened to your console it means theres ether something wrong with your AV lead
Or CONSOLE
before even considering to ring Microsoft borrow a friends wire.
if it still changes colour Call microsoft .
Probably to do with the av connectors inside the xbox
theyll fix it for free if your console is still within the warranty
pls rate.
Sep 01, 2008 | Microsoft Xbox 360 Console
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 picture problem
check vga cables or composite cables
May 24, 2008 | Microsoft Xbox 360 Console
No picture on 360 with white dotted lines.
Make sure that the video connection is properly connected to the TV.. (yellow to yellow) or if using Red Green Blue, make sure colours are connected to the right ports on back of TV)
Also, if you have the option, make sure either HDTV or Normal TV is selected on the back of the connector to the Xbox (IE, if you do not have an HDTV, select normal cable).
Apr 10, 2008 | Microsoft Xbox 360 Console
BadColour
switch the av cable to hd setting
Mar 25, 2008 | Microsoft Xbox 360 Console
Problem with xbox 360
With my xbox 360 as for instance last night i downloaded a new map for halo 3 and shortly there after i started to have issues of freezing the game would stop and lag and i would have a checkered screen come up where ever there was white.
If you have downloaded anything to your hard drive delete it it is probably a corrupted file. IE music game profiles pictures. anything that you have recently downloaded. if that doesnt work i would hope that its under warranty and microsoft can bite the bullet.
Nov 29, 2007 | Microsoft Xbox 360 Console
My xbox 360 is showing green
no red lights, no previous error msgs, and video output on the box has just died. playing halo yesterday and mid-game the colours went askew (like a green overlay) with horizontal banding, backing out to the dash solved nothing so after a reboot there was simply no video. troubleshooted the tv and cables and its definately the box.
http://forums.xbox-scene.com/index.php?showtopic=625804
Nov 11, 2007 | Microsoft Xbox 360 Console
Xbox
Do you have it hooked up straight to your tv or is it hooked into a System Selector? Your cables might be going bad, or what ever you have cables plugged into is going bad.
Sep 26, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
