It sounds as if the drain plug on the back of the unit, down near floor level is loose or missing
Check for that first, because the unit is supposed to shut off automatically, when the drain pan is full. If the plug is leaking or missing, the unit doesn't sense, that the drain pan is full. Also, be sure you exhaust ducts are not bowing down a great deal or trapping exhausted moisture in the duct, that should be exhausted out the window.
Hope this helped you to troubleshoot and solve the problem.
Testimonial: "I think the problem is (was) because the hole that allows the water to drip over the condensor coils was plugged with a bit of debris. "
