Thanks, must have inadvertently slid it to lock position when putting it in the laptop.Thanks, must have inadvertently slid it to lock position when putting it in the laptop.
You can't post conmments that contain an email address.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa: Organize edit and share your photos
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
The a55 doesn't use Compact Flash cards. It uses Memory Stick PRO Duo and SD/SDHC cards. SDHC cards max out at 32GB. Larger SDXC cards will not work in the a55.
Quantaray makes lenses with a variety of mounts. A lens with a Nikon mount, for example, will not fit onto a Sony A55. If the lens has the Sony mount then it will work fine with the A55.
Hi there, please remove the card & check it's locked or unlocked. If unlocked and you face the problem then scan the card by updated antivirus. If your card virus infected then camera can't read the card. So what you do now, format the card and then fix it back in the camera. And try to on . Hope you no face the problem then. Another reason if your card finish his life longer working capacity then error also come in camera display.
Thanks & waiting for your feedback.
