Question about Canon PowerShot SD1000 Digital Camera
PowerShot SD600 My lense is fully extended. I hit the power button and get a message "lens error, restart camera" What can i do to fix?
  • barrychristi Oct 10, 2008
    Ihave the exact same problem...
  • 489 Answers
Hi
What you are seeing is a generic stuck lens error message:
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help!
You can also buy a defective camera online and use the parts to fix one from the two yourself.
Good luck from Darntoothysam com
Thomas
Posted on Oct 13, 2008
The lense of my PowerShot A430 is stuck and thereby renders the camera useless. Is there a way to fix this or should I just buy a new one?
Zoom lenses - stuck in its housing or fully extended are caused by factors like - knocks, dead butteries debris or some form of corrosion .
This is a risky method and I would recommend for the last option, if other conventional methods don't work.
Provided your lens has collapsed into its housing - you try a little knock on the camera with your palm while pressing the on/off button. If that does not work, you are on your own - to decide.
Sep 14, 2014 | Canon PowerShot Cameras
Lense won't extend. Has error screen that says "lense error, restart camera"
sounds drastic but turn on cam and grab hold of lens to try to fully extend it manually. if you hear a crunching noise that means the gears are stripped. not worth repairing
Jul 09, 2009 | Canon PowerShot SD600 Digital Camera
Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 28, 2009 | Canon Cameras
Lens error restart again
Jun 08, 2009 | Canon PowerShot SD600 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lense won't retract on Canon Powershot SD630
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. You're also more likely to be successful trying these than going inside the camera:
Finally, if you absolutely must open the camera, here's a couple guides to replacing the camera's LCD that may help:
http://cannonlcdrepair.blogspot.com/
http://digitalcamerarepair.googlepages.com/sd600
Jan 04, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon sd600 lens error
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Aug 22, 2007 | Canon PowerShot SD600 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
