Question about Kenwood KDC-MP4028 CD Player
Truck radio problem
Im having a problem with my radio in my truck. The unit is kenwood and its brand new. The problem is i cant turn up the volume past 15 or the speakers start to crackle. I thought that the speakers were blown but when i bought new speakers they do the same thing. So after that i put a different radio in to see if it was the radio and that wasnt the problem. I also checked all the fuses and they are good. Im stumped with this problem. The truck is a gmc sierra 1500 crew cab, 2006. help me out please
    Problem Solver:
  • 6 Answers
It sounds like your wires need to be reran you might have a bad wire or two if that doesnt work email me
Posted on Sep 28, 2008
Brake code
Your unit has been previously programed with a code. Is this unit brand new from a shop or did you buy it form someone? If it's new you should contact the shop where you bought it from. If it's from someone, then contact them for the code. Unfortunately there is no way for us to bypass or reset the code...only Kenwood can reset the code. Sorry...
Dec 25, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood KDC-BT558u drains 640 constantly from the Battery even when the unit is off!
check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Jan 06, 2015 | Kenwood Car Audio & Video
I cant lower the volume, in fact many times volume increases when trying to lower the volume and im getting sound out of only the driver side speakers
MOST LIKELY YOU WILL NEED TO REMOVE RADIO AND HAVE IT REPAIRED. OR INSTALL A NEW RADIO. HOPE THIS HELPED. MOTOR 62500...
Dec 21, 2010 | 2002 Mercury Sable
Im Installing an amp and i have a kenwood head unit im not sure what model as i was givin it by a mate. I no that in most head units the remote turn on wire or remote amp wire is blue but im jst checking...
yes there will be a blue wire and maybe a blue with white wire one will give 12volt the whole time the radio is on, the other wire will give 12 volts for 10sec
Jan 07, 2010 | Car Audio & Video
Need key code for kenwood receiver kdc-mp228
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 22, 2009 | Kenwood KDC-MP228 CD Player
It turns off when in high volume
a few things...your speakers may not be a perfect match for the unit. at high volume where the radio starts to distort there is an internal protection circuit that protects the radio...it's kicking in.
solution.  Buy a power amp and take the load off of the radio.
Apr 01, 2009 | Kenwood KDC-MP4032 CD Player
Kenwood new sterio shuts off when turning up volume
You may have a short in a speaker. Check to see that the wire terminals on the speaker itself aren't touching any metal. Even 1 terminal touching metal will cause issues. Hope this helps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
Keep poping the 40 amp fuse on the amps itself when the volume is up at all it seems
Your units drawing too much current. it could be a wireing problem, a speaker problem, or the amp has a problem. the correct way to troubleshoot this would first do or have the amp bench tested. Or you can remove all the speakers and wires and turn up the amp. If the fuse still pops,have the amp serviced. Good Luck
Aug 16, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KDC-MP4028 CD Player Logo
106 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
