Question about Canon LaserClass 2060 Fax
Won't dial through
Machine keeps stating to hang up the phone. The phone is hung up, what could be the problem
    Genius:
  • 2,120 Answers
Is anything plugged into the other phone port on the fax machine? Need the make / model.
Posted on Sep 01, 2008
SOURCE:
I cannot get a dial tone on my Panasonic phone. It says the line is in use.
If this is a multi handset telephone, make sure both handsets are OFF. People have a tendency to simply put the phone down after a call without hanging up, and with some systems it keeps the line open on your end long after the other party has hung up.
Jan 02, 2018 | Panasonic Lands Phones
Why dont I have a dial tone, phone does not work . no ring cant answer when people call
if you have no dial tone , you have no line to the exchange
it can be from the call cancel switch ( hang up button) or an extension that is not hung up properly
It could be an external problem so you will have to get the service provider to check the line from the building out
As that may require you to pay if it is not faulty, try borrowing a phone and plugging it into the wall socket for the phone
If you get a dial tone on the borrowed phone , it is your phone but if there is still no dial tone , it very well could be a service provider problem
Dec 30, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
Phone won't hang up, stays on the line even after hitting 'OFF' button
We recommend you test the main base unit with a different telephone cord on a different telephone jack.
Apr 29, 2014 | Panasonic KX-TG5652 Twin Cordless Phone
When I dial number the screen blacks out & if it goes to message bank on the other end I cant hang up untill other end is finished & hung up this is a motorola defy smart phone
The only known solution to this i can think of is if you are using a task killer it is killing vital functions and causing the bug. Try disabling it or using a different one.
Mar 10, 2011 | Motorola Mobility Defy Cell Phone
Brother Intellifax 770 - can not fax out
You probably need a prefix to dial out of your office. If it's a home fax machine, you may need to dial the number "1" plus the phone number you wish to dial.
Jun 25, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Uniden 1725 no dial tone
I had the same problem as long as they are plugged in correctly and you put the #2 handset into the #1 cradle to register it to your base then try hanging the phone up several times. These are expandable phones so that I believe you can keep adding other handsets. So sometimes they think you have a few more handsets than you really have so when you hang up it may not know what handset you are hanging up #1 #2 or #3 #4 etc. So I had to keep hanging them up until it finally hung up. Then I had to re install them so it knew I only had 2 hand sets. So then you start from the beginning, like when you took it from the packaging. I hate these phones. I ended up replacing them with different ones. Plus I always keep a rotery phone laying around put away because during a power outage you still can plug in an old dial phone and it will work! Nothing like old technology.
Feb 15, 2009 | Uniden 5.8GHz Dual Cordless Phone
Hung up!
Heya U Need to FreeUp ur Memory First -
If not Done Delete Unwanted Files From both
Memory Card n Phone -
Use File Exploerrer To delete Unwanted Phone Mem. Files
If Not Done Use Mobile Disinfector Antivirus n Scan Ur Mobile Ur With PC:
Always Keep Ur Memory Somewhat free.
It Helps . Helped.
Jan 10, 2009 | Nokia N70 Cellular Phone
Panasonic kx-t7730 plays music when phone receiver is on phone
HANG UP THE PHONE AND PRESS 1 THIS WILL STOP THE BACK GROUND MUSIC.
Dec 13, 2008 | Panasonic KX-T7730 Corded Phone
LIne In Use/Answer On Message
Just some Tips - Do you have any other phones or fax machine in the house? Check to make sure they are all hung up or press the off/ hang up button. If so, disconnect them until one brings back a dial tone when disconnected Also try cleaning the charger contacts with an eraser to the charger sends a signal that the phone is hung up.
Hope this helps!
Apr 27, 2008 | Uniden Cordless Phone
Answering phone system cannot handle nuisance calls
i have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
Feb 05, 2008 | Panasonic KX-TG5632 Phone
Canon LaserClass 2060 Fax Logo
Clive
Clive
old marine
old marine
Ekse
