It could be that your cartridge needs cleaning. On your computer, go to Start menu > All Programs > Lexmark 2600 Series Printer > Tools > Lexmark All-In-One Center > Maintenance > Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. You can also try to manually clean the cartridge nozzles. Remove your cartridges from the printer. Wipe the cartridge nozzles using a slightly moistened soft cloth. Reinsert the cartridges into the printer. Try to print again.
If problem continues, try to insert a different known working cartridge to determine if the other is faulty.
For Windows OS:
1. Go to Control Panel.
2. Open Printers and
Faxes.
3. Right-click on Lexmark
3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print
using black ink only. Click OK.
6. Click OK button in the
Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in
black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish
to print) open, go to Print. A window will pop up.
2. Select the Lexmark
printer.
3. Expand the arrow
pointing down beside printer name if you're not able to see other options for
printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black
and White.
5. Save this as your
default print setting. Click Presets option and choose Save as. You can
personalize the name for this default print setting (e.g. Black and White Draft
or My Setting).
Select this Preset name
every time you print your files/documents.
There is no error 5100 in the manual so look at the following:
(1) Operator call errors (by LED blinking in orange)
LED blinking in orange. Error Solution Remarks
2 times No paper. Set paper, and press the Resume/Cancel button.
3 times Paper jam. Remove the jammed paper, and pressthe Resume/Cancel button.
4 times No ink. Replace the empty ink tank(s). (Pressing the Resume/Cancel button will exit the error without ink tank replacement.)
5 times The print head is not installed properly. - Install the print head, and close the
front cover.- With the print head installed, turn theprinter off and on.
- Re-install the print head.
8 times Warning: The waste ink absorber is almost full (approx. 95% of the
maximum capacity). Pressing the Resume/Cancel buttonwill exit the error, and enable printing.
In repair servicing, replace the bottom case unit (QM2-0647), or 5-item set of
the ink absorbers
(QA4-1012/1013/1014/1015/1055).
The service call error, indicating the waste ink absorber is full, is likely to occur soon.
9 times The connected digital camera or digital video camera does not support
Camera Direct Printing.
After removing the cable between the camera and the printer, press the Resume/Cancel button, and re-connect the cable.
(2) Service call errors (by LED blinking alternately in orange and green, or lit in
orangeLED alternate blinking in orange and green
Error Solution
(Replacement of listed parts, which are likely to be faulty)
2 times Carriage error - Carriage unit (QM2-0655 / QM2-0831)
- Timing **** strip film (QA4-1053)
- Logic board ***'y (QM2-0750 / QM2-0751)
- Carriage motor (QK1-0175)
3 times Paper feed error - Timing sensor unit (QG4-0277)
- Timing **** disk film (QC1-2781)
- Feed roller ***'y (QF4-0155)
- Platen unit (QM2-0650 / QM2-0828)
- Paper feed motor (QK1-0224)
4 times Purging error - Purge unit (QM2-0825)
6 times Internal temperature error - Logic board ***'y (QM2-0750 / QM2-0751)
7 times Waste ink absorber full - Ink absorber (QA4-1012 / 1013 / 1014 / 1015 / 1055)
- Bottom case unit (QM2-0647)
8 times Print head temperature rise - Print head (QY6-0042)
9 times EEPROM error - Logic board ***'y (QM2-0750 / QM2-0751)
13 times USB Host VBUS overcurrent - Logic board ***'y (QM2-0750 / QM2-0751)
- DCD board ***'y (QM2-0825)
15 times Other hardware error - Logic board ***'y (QM2-0750 / QM2-0751)
Continuous alternate blinking
Flash ROM error - Logic board ***'y (QM2-0750 / QM2-0751)
Lights in orange
RAM error - Logic board ***'y (QM2-0750 / QM2-0751)
Hop you can understand the above as it is straight out of the service manual.
Good luck
