Question about Lands Phones
My Phone won't send dial my calls and vw access is on it - what does that mean
  • 19,396 Answers
Try disconnecting phone from power for 5 or ten minutes, this will reset phone settings, check also phone cable.
Posted on Aug 21, 2008
Phone display says Sent 140?
Sounds like by default you pick up intercom depends on what flexible access code 14 would do... Or even 1.. Some people use one to transfer directly to voicemail.. So maybe your sending an air out call to extension 40 to voicemail.. Unlikely but no way to know unless you know what flexible access code is.
Feb 05, 2014 | Toshiba Lands Phones
Unblock phone calls from phone
need more details on problem.
do you have access to programming the pbx?
do you mean that others using the pbx cannot call?
are they allowed to access a dial tone, but cannot dial out?
Oct 13, 2013 | Panasonic KX-T7730 Corded Phone
3Com 3102 phone dial tone but won't dial out
As long as someone hasn't been poking around in the phone system, this is a phone company issue. I have seen this many times and it has always been a carrier issue. Typically with PRI's or integrated access analog lines.
May 08, 2012 | 3Com NBX 3102 IP Phone
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
Internet drops out when phone rings
First I'll assume that you have wireless broadband internet access. In which case the interruption is caused by your cordless phone. Cordless phones are usually 2.4 Ghz now and so are routers. Operating on the same frequency causes interference between them. Get a phone that is not 2.4 Ghz.
If you have dial-up internet access, then this is most likely caused by your dial-up connection being interrupted. Any time someone tries to call you this will happen unless you call your phone company and they can help you take the proper steps to make sure that this doesn't happen (usually that means they'll tell you how to disable call waiting).
Apr 12, 2008 | Computers & Internet
Call Forwarding
tell her to dial *72 followed by your home phone number then press send on your cell phone. she will hear a stuttering dial tone. the calls are now being forwarded. when you get ypur cell phone, press *73 then send to deactivate the call forwarding.
wg
Feb 07, 2008 | LG VX-8700 Cellular Phone
Lands Phones Logo
49 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
