Question about Olympus Camedia C-310 Zoom Digital Camera
Olympus c-130 camera
On/off switch does not work in position two so camera does not work
Where can i get a memory card for my olympus fe130?
Try Staples. Just make sure that you do not get a card too big for camera - otherwise it will not work with the memory.
Oct 05, 2016 | Olympus FE-130 5.1 Megapixel Compact...
How do i unlock my memory card on my canon IXUS 130 camera?
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 13, 2011 | Canon PowerShot SD1400 IS IXUS 130...
My olympus fe-130 keeps saying card error. I was taking photo's & then that appeared on the screen. It won't allow me to retrieve my photo's. The camera works fine when the card is out.
Most likely ur card is corrupt. take the card out and there should be tiny slider on the side of the card with arrow showing in one direction. ur card , slide it from where it is to the other side and see if u can retrieve ur photos or make it to work again. even if it works again , take ur photos out and format the card before u use it again.
Goodluck.
Jul 27, 2010 | Olympus FE-130 Digital Camera
How do i take off write protected on an olympus 6010
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 18, 2010 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
I normally use a small 32mb memory card in the olympus D-390 but used an olympus fe-130 over the holidays with a 256mb memory card. I do not have the usb cord for the fe-130 so I put the 256mb card in the...
Many cameras will not read cards written on other, different cameras. There should be no problem taking the card to a store and having the pics printed or put on a disc. Or get a cord for the 390, or a card reader for your computer.
Dec 27, 2009 | Olympus Camedia D-390 Digital Camera
Blue screen with options is coming
This is a board failure only Olympus will recommend next course of action
Sep 20, 2007 | Olympus Stylus 710 Digital Camera
Olympus fe-130
This need looking at - Check Olympus Tech Help- especially if it is a recent purchase
May 22, 2007 | Olympus FE-130 Digital Camera
Olympus fe-130
Make sure your cable is OK. 1: Make sure you don't have any damaged pins on the plug on your camera and on your USB port on the computer Try using a different cable to be sure that is not the problem. If you can t ry a different camera on the same cable and make it work, your camera is at fault. Try it on a different USB port, and possibly also on a different computer to make sure the port on your computer is not at fault. Check both cable ends and the ports on the camera and computer are not dirty
May 18, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130 Video Playback has no volume..............PLZ HELP!!!!
well did u use zoom while u made the videos???? if u did forget because the camera while doing zoom doesn´t record sound, u didn´t use zoom, probably the camera microphone needs to be replaced.
Feb 09, 2007 | Olympus FE-130 Digital Camera
Olympus Camedia C-310 Zoom Digital Camera Logo
662 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
