Question about Packard Bell Computers & Internet
My power pack on my packard bell tower has gone kerput got a replacement but that long ago i have forgotten where the 7 (looms)go into their sockets. could you help please. DENNIS SUTCLIFFE
SOURCE: PACKARD BELL COMPUTER TOWER
Hi, sounds like your hard drive is going/gone flaky...  & if so ya gonna haveta get a new hard drive & a Windows Operating System.
Or take it to a good PC repairer, and get a quote and  explanation.
Posted on Oct 15, 2007
  • 9 Answers
SOURCE: sound device
You can locate drivers for just about ANY older system (ala "Packard Bell") and it's devices on Driver Guide (it's saved MY life a few times).
Go here:
http://www.driverguide.com/
Posted on Nov 30, 2007
McIndia
  • 131 Answers
SOURCE: Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
Posted on Jan 05, 2008
priyabrat
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
SkullyFox
  • 93 Answers
SOURCE: front usb connections
front usb jumpers on the board are usually a small cluster of 9 pins, usually found down the bottom of the motherboard, and labeled fusb, or USB_H, or something similar. the front usb connectors have 2 sets of wires (8 in total) and are black, green, white and red. if the front connector is one whole plug, just plug it onto the header the right way and it should go.. if the pins are all individual.. you will need to push them down one by one in the right order.. easiest wat to do it is plug both the black ones on the first 2 pins after the single one, then the 2 greens side by side, then the whites, and finally the reds on the very end.
. red . wht . grn . blk . blank
hope this helps
Posted on Jun 13, 2008
My tower wont turn on
Obvious places to start is checking that the power cable is in all the way, switched on at the wall socket and that the fuse hasn't blown in the plug/extension lead. If they're all ok it could be a dirty contact or a faulty switch on the power button, a loose connection attached to the switch or worst case scenario your main PSU (power supply unit) has died. It's not the end of the world if it has, swap out the old one and invest in a quieter replacement from QuietPC
Oct 08, 2010 | Packard Bell Computers & Internet
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
Cant trace aux in jack
The green is usually the audio out and the blue is audio in.
To test the jacks to determine which is which, insert an audio CD in the CD/DVD drive to get audio sound and plug headphones into the each of the jacks, the one without sound will be the audio in.
Jun 30, 2009 | Packard Bell Computers & Internet
Need to remove case to change DVD writer
Check the back of the PC case, There maybe a screw that needs to be removed in order to open the side panel. Another thing could be that there is some kind of sliding lock, that is holding the panel in place. Keep playing around in the back of the case, most likely you'll find it within a few minutes.
May 27, 2009 | Packard Bell (ATXMH28AP) Full Tower Case
Remove he dvd drive from Packard Bell computer
Remove both left and right panals on the tower. Disconnect the IDE ribbon cable and power from back of the cd drive. There also may be a small wire that connects ether to the sound card or motherboard also. Remove all screws from the right and left side of the device. Push the drive out the front.
Jan 19, 2009 | Packard Bell Computers & Internet
20 minutes ago my computer was fine, its a packard bell imedia 3051. i turned it off the usual and proper way and switched it off at the wall. i just switched it all back on and now it wont even turn on i...
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to unplug the power cord from the tower and also remove any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers mouse, keyboard).
Nothing should be connected at all to the tower.
Now Press and hold the power button on the tower for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the Power, keyboard and mouse and check, it should certainly work now.
Hope this should help
Regards
Sammy
Aug 28, 2008 | Packard Bell Computers & Internet
I have a packard bell imedia 5050 desktop when switched on only shows a orange light and will not power up from there can you help ?
Sounds like a power supply. the power supply in the tower may have overheated or burned. Does the fan in the power supply come one?
Jul 11, 2008 | Packard Bell Computers & Internet
Oct 15, 2007 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
