Windows reboot i attempted to reboot my system the other day and it would stop in mid installation tellling me that i had no hard disks installed and that if i had a floppy disk in the A:drive to remove it though i have a laptop with no A: drive. I no longer want to continue installation however every time my computer is turned on it asks if i would like to continue setup and i was wondering how to stop that and just get it to start up without the set up message coming up
  • 1 more comment
  • rcarrol Aug 22, 2008
    I do have a working system of windows installed though i would like to finish setup its just that the setup wont install.
    What would i select to stop the setup once im in the f8 menu?
  • rcarrol Aug 24, 2008
    i tried to re-install windows OS to eliminate a virus however it would not finish setup because of a stop error coming up as a blue screen and it tells me to restart my computer
    When i restart the computer in the first black loading screen it gives me 5 seconds to either choose to start windows normally or to continue with setup however whenever i choose to continue setup the stop error on the bright blue screen still appears and the cycle continues except if i choose to start normally then the computer works fine so how would i stop the choice of getting the choice to continue setup?
  • rcarrol Aug 25, 2008
    would it be okay to delete the setup from the boot.ini file or would that cause problems for the computer?
  • 13,433 Answers
If its a windows setup.. well you can try pressing f8 in the startup. but you need to finish the setup if you don't have a working system installed.
Posted on Aug 22, 2008
  • 4 more comments
  • Ekse Aug 22, 2008
    you would select the 2nd working installation of windows and press enter to start it up. but if you don't have a 2nd windows on the list then you don't have another windows which is correctly installed and you can't startup other than the setup.
  • Ekse Aug 24, 2008
    how can i help you?
  • Ekse Aug 24, 2008
    I noticed that I receaved a Inappropriate rating from this solution, how can I help you to solve the problem?
  • Ekse Aug 24, 2008
    If I understood you correctly, you have a fully working windows installed and the setup.
    so start the working windows, press the start button -> run -> type in msconfig open the boot.ini tab
    select the working installation of windows from the available options and click on set as default
    the computer will now automatically start the working copy of windows after the timeout.
    you can change the timeout to a few seconds to speed up the startup.
    optionally you can go into c:\ find the boot.ini file, it is a hidden system file, you need to enable showing of hidden and protected system files.
    open the file in notepad and remove the setup option from the file, this will skip the timeout and will not ask you to boot up the setup as there is only one entry on the list and it will start that automatically.
  • Ekse Aug 25, 2008
    Mind changing the rating?
  • Ekse Aug 26, 2008
    no, it only removes it from the startup list, make sure you only delete the one line, as if you delete the wrong one, you wont be able to start up the working one.
What is the boot disc and how do i install it
If the Windows operating system is installed on your hard disk then the boot disk disk is your hard disk. If your computer cannot find the boot disk then the hard disk maybe faulty.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 14, 2012 | Acer Computers & Internet
Several attempts to install windows 2003 on dell optiplex 780 have been unsuccessful. all i get each time is a blue screen.
Windows 2003? There is no operating system called "Windows 2003". There is Windows 95, Windows 98, Windows ME, Windows 2000, Windows Milenium, Win Xp, Win Vista, Windows 7 ect. But no Windows 2003.
If you are trying to install an operating system on a Dell computer, put the disk in the cd or dvd drive on the pc and close it. Then turn the computer off and reboot it with the disk in the drive. After the computer reboots, it should recognize the disk in the drive and bring up the installation process automatically. Sometimes you have to reboot the computer 3 - 4 times in a row with the disk in the drive in order to get it to recognize the software and boot from that drive.
If the Dell does not have an operating system on it and you are trying to install windows from a disk, it may not auto recognize the program in the drive and the above instructions will not work. If this is the case, then you need to put the disk in the drive of the pc and restart/reboot it - and watch the computer screen as the pc restarts - look at the lower left side of the screen during the boot up process to see what keys you need to press to enter startup mode, or get into the bios system of the computer. when you boot up a pc, it will display the keys you need to press on the screen for a brief few seconds before the "windows" screen appears and it completes the start up. If the pc is running windows xp, the command keys to press during start up might be F2 - F8 or "press the delete key". The commands can differ depending on which version of windows you are using - and they can also vary by brand of pc too.
You need to put the pc into "safe mode" or get into the Bios system or restore area to install windows if the computer does not already have an operating system installed on it.
To put the pc into safe mode or get into the Bios System, you need to press the right keys during the start up - and do this before a picture appears on the screen or the windows display comes up.
Put the disk in the drive and reboot the pc. As soon as it starts to reboot, keep pressing the F8 key. If the pc does not go into Bios or say "loading safe mode" then immediately restart the pc and try again. Sometimes it takes 3 or 4 attempts to make this happen. If the F8 command does not work after 4 tries, then try the F2 key. After four tries if that does not work - try pressing the delete key.
If you can get the pc into the bios system - use the arrow keys on the keyboard to scroll through the options and find the prompt that says "boot order". change the boot order to boot from the Cd or Dvd drive instead of the hard drive. Save after changing this setting and reboot the pc with the disk in the drive and it should boot from that disk to install the operating system. Try rebooting 2 or 3 times after changing the boot order to the disk drive to get it to boot from the cd. Then just follow the prompts to install the operating system and your done!
Jul 07, 2011 | Computers & Internet
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
Attempted system recovery on HP a1540n. Only option allowed was to format hard drive. Computer now stops at splash screen. Boy, I need help. Thank You, Gordon
By formatting your hard drive, you've wiped all the data.
You now need to re-install an operating system.
If you have a Windows installation disk, just put it in your CD/DVD drive and re-boot, follow instructions.
If you don't have an windows installation disk, its a case of buying one, make sure you also get the COA Code of authority, 5 groups of 5 letters and numbers.
If you don't want to pay for a system disk, Download and burn a copy of one of the Free Linux operating systems. Ubuntu is my favourite. Just log onto :- http://www.ubuntu.com/ and follow your nose.
Again, when you have a disk, put it in the drive and reboot.
Nov 23, 2010 | Computers & Internet
My computer worked fine until one day I attempted to turn it on and it said operating system not found. What happened? Can this be fixed?
This error message could be caused by :-
Check the BIOS to see if it detects the hard disk
If not the hard disk may be faulty or needs reseating. If the hard disk is faulty it needs to be replaced and Windows installed on the new hard disk.
A virus program may have infected the computer and removed or changed some system files - in this case Windows needs to be repaired OR Windows re-installed - this is the best option.
Aug 11, 2010 | IBM ThinkPad X41 Notebook
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Operating system not found
This means it cannot find the Windows OS files because either:-
The hard disk has failed or it needs reseating.
or the hard disk controller has failed.
or the Windows files have been deleted or corrupted (maybe by virus)
Try reseating the hard drive.
If the hard disk is faulty, you need a new one.
Try using your recovery CD disk.
Try re-installing Windows
Feb 24, 2009 | Acer Aspire 5050 Notebook
Installing LaCie Mobile USB disk killed my Windows 2000 server
First, remove the usb disk, then when the computer boots up, press F8 continuously. Run the Safe Mode and try to uninstall the usb software and driver.
Jan 13, 2009 | LaCie 160GB Mobile Disk USB2.0 160 GB Hard...
40Gb hard Disk
installation continue with 3 rebooting - restarting an dthey are automatic. just wait and look! do not tach!
Sep 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
