The blinking error codes on the TV tells me the V-deflection on my Sony KV-27S36 has problems. How much does this typically cost to repair? Is this something I could repair myself?
  • kad7b Aug 21, 2008
    Thanks. I'm debating whether or not the $200 is worth fixing an 8 year old TV.
    Genius:
  • 2,920 Answers
You will need to take it in for repairs typically its about 200 to get repaired depending on the shop you take it to
Posted on Aug 21, 2008
  • Ronnie Houston Aug 21, 2008
    you might just want to buy a new tv 8 years is old for a tv anyway
Sony 36inxbr and it will not turn on
A lot of these are not getting fixed as very heavy set--typical repair in our shop is usually over 150 dollars and goes higher in some cases.
If the red power light remains and blinks look for the number of blinks and then a pause and repeats that ---if so that is an error code.
Most common failures in this set are on the D board--D for deflection.
Dec 17, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
KV-34hs420 LED Blinks 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Apr 28, 2012 | Sony KV-36XBR400 36" TV
My sony kv-27fs13 has a problem .. the standby light flash 4 times . What is it ?
Hi there
In sony tv`s the 4 blink code(sony error codes)usually indicates a vertical deflection problem.
Your vertical output i.c and/or related components are probably faulty and need to be replaced.
If you feel that your up to repairing it let me know and i`ll see what i can do to help.
Merry Christmas
Dec 24, 2009 | Sony KV-27FS13 27" TV
KV-32HS500 WON'T TURN ON standby light flashes 7 and sometimes 6 times and has flashed 4 times also.
These are sony error codes while in protection mode. The 7 blinks means high voltage exceeded 33k volts ,caused by either horizontal or power supply circuits.
The 6 blinks code is for no horizontal deflection, and the 4 blinks code is for no vertical deflection.
So the one thing they all have in common is the power supply that will need to be repaired before you can use the set again.
Hope this help. Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 02, 2009 | Televison & Video
KD34XBR960- NO PICTURE blinks 7 times. Thanks
Horizontal Deflection
Stopped
7 times 7:0 or 7:1 • No picture
Horizontal Defl ection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
IF YOU WANT TO DOWN LOAD A FREE SERVICE MANUAL OR TECH MANUAL FOR YOUR T.V. HERE IS A SIGHT THATS TOTALY FREE
http://www.schematicsforfree.com/archive/dir/Sony/Video
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony KV-32FS13 TV
SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Oct 01, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony kv-32fs13 4 blink code
The tech is wright about the deflection board having a fault. This failure is found in the vertical deflection circuitry.
The quote is the one that seems to be a bit high, instead of getting this TV fix; I would save that money to buy another TV.
Good Luck.
Jul 24, 2008 | Sony KV-32FS13 TV
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
Electro Med Services...
