Question about Uniden Vehicle Parts & Accessories
Replacement Audio/Mute switch...
Greetings,
Trying to source a replacement Audio/Mute switch for an old Uniden RD9XL around a 1989 vintage. I don't believe there is any direct support for the model any longer, but the rubber/vinyl coated 2 position switch itself may be able to be tracked down from old service diagrams w/parts listing callouts. Reply to russ_bentley@yahoo.com Thanks in advance!
Opened my unit and read off the P/N of the switch. Looked it up on the mouser website and led me to NKK switches and found the one in there. DONE...
Posted on Aug 23, 2008
Vintage Audio Repair in the NYC/NJ area
The hum is a tube that has gone weak or a volume switch that may be going out! Try a TV repair shop in your area, and call first so they can tell you if they are familiar with the old equipment!
Oct 21, 2013 | Audio Players & Recorders
How to connect a vizio lcd hdtv to my 1976 kenwood KVA 503. My Vizio has no speaker outputs except a digital optical audio. I had it hooked up before and then moved and now I can't get it back...
Obviously the digital optical connector was never connected to the vintage Kenwood.
It sounds like your Vizio is NOT the actual root SOURCE of the TV audio but it's coming from a Cable Box which DOES have various audio outputs. Connect it as you would any other analog audio source (except don't use the PHONO input).
Jun 30, 2011 | Audio Players & Recorders
Just got a vintage Onkyo receiver mod # TX-840. I have a very scratchy sound in both A and B right channels on all sources. Figured it was a blob channel HOWEVER this unit has a
Vintage hardware means vintage contacts on all the controls which means oxidation which would cause crackly sound or total silence. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts. Beyond that a trip to the hifi doctor would be advised.
Jun 21, 2011 | Onkyo Audio Players & Recorders
I am trying to use a singer featherweight II but I can't figure out how to thread the machine no manual
Is this a very old machine because the manual I"ve located doesn' look like the image on Fixya.
Try this link http://www.singerco.com/uploads/download/997_white-117.-kenmore-x.pdf
Singer have various model manuals downloadable, you just need to search them at their website page http://www.singerco.com/accessories/instruction-manuals/search
Trust this helps you out.
If you don't resolve the issue and this is a vintage machine, then there is some good user groups such as Vintage Singers under Yahoo where enthusiasts share info on their old machines. Good to lurk though or go through old threads first as there is often someone else who has asked similar question in the past. There may also be manuals in their files so have a dig around.
Jun 06, 2011 | Singer Featherweight II 117
I have a JR-S501 receiver that cuts out on the sound. The turntable works OK when hooked to another amp. Thanks for the help
So are you saying you have a turntable-only issue with the JVC (guessing about the brand)?
Does the JR-S601 work OK otherwise?
Given its vintage there could be oxidized contacts throughout which would cause crackly sound or total silence.
If it's only an certain source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Have you looked in the manual?
Mar 23, 2011 | JVC Audio Players & Recorders
Trying to source an off switch for bang@olfusen beomaster 2200 vintage 1977 1980
B & O use CPC for parts and spares. If they don't have one I suggest you contact B & O for advice on what to replace it with, as mains switches are safety parts and should be replaced with the same type where possible.
Jan 12, 2010 | Audio Players & Recorders
Vehicle Parts & Accessories Logo
161 people viewed this question
Top Uniden Vehicle Parts & Accessories Experts
Steve
Steve
Kulu Criss
Kulu Criss
Marvin Steele
Are you an Uniden Vehicle Part and Accessory Expert? Answer questions, earn points and help others
