Question about Mitsubishi WD52527 52" Projection HDTV
Random purple spots on screen
I purchased a 52" LCD Projection TV two years ago and lately I'm noticing alot of "purple spots" appearing on the screen. The screen is clean and I'm not quite sure what is causing this - any ideas??
  • 3 more comments
  • Anonymous Oct 10, 2008
    Purple spots on screen 60" 3 years old.
  • Anonymous Dec 03, 2008
    I have the same problem, I am being told that it might be a bad lamp. Mine is a Mitsubishi WD-62528. If anybody has a better clue please let me know.
  • Gary Jan 03, 2009
    I have a Mitsubishi WD52527 and I have random purple spots on the screen. I replaced the lamp and it DID NOT fix the problem. I had the technician from the store I bought it from come and take a look and he said the only solution is a new light engine at aprrox. 900-1000 dollars to replace. My TV is only 3 years old. Any other ideas?
  • madelinemix Jan 08, 2009
    Same prob with a Mitsu 52 from about 2.5 years ago. I read in the manual to clean the filter on the back... haven't tried cuz I need another set of hands to help 'de-mount' the TV. I really hope its no anything besides the lamp. I was told when I purchased the TV that the lamp will eventually need to be replaced...so, I was expecting that..
    If you have to buy a lamp, lookup the model # of Mitsu (or other Manu) website, but search for the part on-line. The TV Companies double the cost... I've found lamps for my TV for as little as $110 dollars. Mitsu wants like $300 for the same exact Part # and everything.
    check this:
    http://www.bigscreenforums.com/forum_top...
    the second entry seems to have some info that may help some of ya.
I have the same issue with the WD-52528. I was told it may be a bad light engine. Service is coming out August 27th. I'll let you know what they say.
Posted on Aug 26, 2008
I have colored spots appearing on my screen when the TV is on. The spots are 2 to 6 inches in diameter and always appear in the same locations at various places on the screen. The first spots I noticed...
the light engine (optical block) is failing. there are lcd panels and light filters in the light engine. the problem your having is that they over heated and the image is burnt into the lcd or light filter. my be caused by a failing fan or just it's life span. the lcd panel or light filter are done for. you can keep calling panasonic and bug them over and over and they may send you a new tv. sony sent me one after 5 phone calls. i had the same problem. hope this helps.
Jan 14, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Yellow & purple spots permantly appear on the screen
Hi;
Unfortuntely its time to replace the optics engine, Engines make up about 80 percent of the television, replaceing the optics engine will be like purchasing a new set. There is no way to address this problem but to change the optics engine, A good place to purchase one new or rebuilt is www.tristatemodules.com
Jun 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Purple spots in the screen
I'd like you to try doing this, select the service menu, and if the spots are still there, it's an issue with the DMD Board but on the contrary it might be the Digital Video Board. If you're decided to purchase the board check discountdashmerchantdotcom they have pretty accesible prices and good service, the only thing is that they only offer warranty to service centers, but they're good :)
Jun 29, 2009 | Mitsubishi WD-52528 52" Television
Hitachi lcd projection tv screen discoloration model 50vs69a
probabally a dust spot on the mirror or the lcd mini panels inside the optical engine.
must be dissembeled to clean.
not for the faint of heart.
Jun 13, 2009 | Hitachi 50VS69 50" Projection HDTV
Pink and Blue Spots
Contact sony as they have been helping customers with the blue spot issue on alot of the wega as the optical block fails causing the blue spots.Sony will cover the cost of the repair. Heres the link to Sony explaining what they will do.
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Nov 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Mitsubishi WD52527 52" Projection HDTV Logo
510 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
