Question about Car Audio & Video
JVC KD-G351 question
Should the JVC KD-G351 be working like this:
All radiostations and settings are stored and they remain even if I turn off the car.
The radio is working well when the car is running, (also CD and USB or MP3), or when the ignition key is on power.
When power is off (no key in ignition), the stereo only accepts the eject or disp buttons, in other words, can't get any music out of the set unless power is on in the car.
Every other set I have installed works like this:
When turning off the car and removing the key, the stereo is also turned off, but pressing the "ON" button starts up the stereo again, even if the key isn't in.
  • anzziwill Aug 21, 2008
    Oohh...! You haven't? I checked on both my other cars, one with an LG stereo, and the other one with a set that was in the car from the beginning, and they both work like that. But I also asked my collegues how it works in their cars, and it works exactly as in my car, except for one Toyota owner that said he has to turn the key into the first position before he can turn on his stereo, but then again he hadn't tested to just push the "ON" button on the stereo while the key was not in the ignition.
    I'll have to check out a little bit more about this, someone suggested a fuse could have gone, but it sounds strange as I would think it couldn't work at all then...
    But thank you for your advice, and of course other could enlighten me in this question also if they have tested to push the on button without having the ignition key in power position.
  • 218 Answers
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Posted on Aug 21, 2008
What is the sound ic number for jvc kd g351
Posted on Feb 15, 2010
Looking for a Tech instruction manual for JVC KD-W5Double cassette deck. (LATE 1980s)
I haven't seen the instruction manual anywhere (even for sale) for your specific model number.
A couple of ideas for you:
The JVC TD-W354 manual is available online it's also a Double Cassette Deck, perhaps some of the settings are the same? -
Also Hi Fi Engine has the JVC KD-W55 manual online, but you have to join their website to view it -
Good luck in your search!
Apr 04, 2017 | JVC Car Audio & Video
How to set time on JVC KD-R200 car radio.
Try this.
Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Feb 09, 2015 | JVC KD-R200 Car CD/ MP3 Player
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
JVC KD-G230 will not work after my battery died
the battery probley shorted out your deck i think its time for a new one
Jan 11, 2010 | JVC KD-G230 CD Player
Turns on then off right away
Hello headbanger42,
First I'd check all of the wiring and connections. Make sure that there's no bare wires, no cut or frayed insulation and no wires contacting metal on the vehicle or other wires.
If everything is connected properly and there's no shorts, press the reset button on the panel holder using a ball-point pen after detaching the control panel. (The clock setting and preset stations stored in memory will be .)
If that does not work, there's most likely an internal fault and the receiver needs service.
Hope this helps.
Jun 02, 2009 | JVC KD-SX980 CD Player
Install JVC KD-G351 into a toyota corolla 1998
if you go to your local audio store they should sell a kit to wire in your radio, so you dont have to cut any wire on your car it will just plug right in to the factory wiring
Dec 29, 2008 | Kenwood KDC-MP335 CD Player
JVC KD-AVX33 pairing problem
To inicialize to factory settings do: In "Setup" menu go to "others" menu, go to "Initialize" press "Enter".
With this you will loss all your customized settings
Sep 25, 2008 | JVC KD-AVX33 Car Video Player
Not reading MP3 cds
Have you tried removing the negative terminal from your car battery and giving it a few minutes. Hook the terminal back up and try your cd player again? That should be the same as resetting your cd player settings.
Sounds like you have a problem with the mp3 format being used.
Apr 19, 2008 | JVC KD-G501 CD Player
I c an't set the time in my jvc kd-g120 audio cd player
Push the Sel button and hold for 3 seconds (usually displays Demo or Demo Off). Push the Station up and down button til it reads Clock H or Clock M. Turn the volume button to adjust time. Push the Sel button to quit.
Apr 30, 2007 | JVC KD-G120 CD Player
Setting Clock for JVC-KD-G420
Here is the link for the manual page 7 Hope this helps :)
Mar 17, 2007 | JVC KD-G420 CD Player
Car Audio & Video Logo
409 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
