Question about Konica U-Mini AF 35mm Point and Shoot Camera
Konica Zoom FR735 Camera
I have a Konica Zoom FR735 Camera and it seems to have a slight problem -- I am unable to locate my manual so I am hoping that you can help me.
When you turn the camera on -- it will not stay on -- I have put a brand new battery in it. But when I turn it on -- there is a number 88 or 51 in a box that flashes and it also has arrows going to each one of the features (such as red-eye,flash etc.) Can you please help me with this problem or lead me to where I can download a manual.
SOURCE:
  • 91 Answers
SOURCE: Problem starting the camera, viewfinder LED just flashes one time.
chances are good that your camera needs to be formatted although they recommend that you do it from your camera and not from your computer
Posted on Aug 10, 2007
ginko
  • 19396 Answers
SOURCE: user manual for Konica KD-25 camera needed
You can download the manual from the link below, do not forget to rate the solution.
User Manual Konika Revio KD-25
Thanks.
Posted on Feb 27, 2009
ginko
  • 19396 Answers
SOURCE: EEE error on my Konica Hexar AF
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Posted on May 30, 2009
Obertelli
  • 3006 Answers
SOURCE: how come when i go to turn on my camera it just
This is very likely to be a lens mechanism error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sony service department in your country (Sony took over Konica Minolta) to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 25, 2010
  • 11967 Answers
SOURCE: Konica Revio KD-400Z. Internal battery appears to
First the bad news. Konica got out of the camera business in 2006...all service is now handled by Sony. The internal battery is not user replaceable. It is a rechargeable battery that recharges itself from the regular battery. It takes about 3 hours to accomplish this. If you remove the main battery for 24 hours, the internal completely runs down and all date and time settings are lost. If after setting them again, you don't leave the fully charged main battery in the camera for at least 3 hours, they will disappear again.
Posted on Oct 12, 2010
Manual zoom does not work when I try and use it
Most likely the motor mecanisim was damaged when you dropped it. was unable to locate a sony dealer in nepal, You could try Sears if there is one in nepal.
Hope that was helpful.
Nov 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
No possibility to focus objekts
Your lens elements are not moving smoothly. Maybe gummed up.
Mar 01, 2012 | Konica Minolta DiMAGE Z10 Digital Camera
I have a konica minolta model 2806-301 and i need an instruction manual for it can you help me?
Really, you are talking about Konica Minolta Dimage Z6 6MP Digital Camera with 12x Anti-Shake Zoom:
MPN: 2806-301
Model: 2806-301
Optical Zoom: 12
Digital Zoom: 4
Maximum Aperture: 2.8
Maximum Focal Length: 69.9
Minimum Focal Length: 5.83
Maximum Resolution: 6
Maximum Vertical Resolution: 2112
In this link coudl find your User Guide: Konica Minolta DiMAGE Z6 (down page, enter verification code to download user manual).
Hope helps (for free, remember to rate this answer).
May 16, 2011 | Konica Minolta Cameras
NO MANUAL OR DISC FOR MY CAMERA
Hello Carrmaher, here is a direct link to your camera's owners manual.
http://sanyoservice.com/pdf/images/VPC-S500.pdf
If you are unable to open it please go to www.adobe.com and download adobe acrobat reader.
Hope this helps you and please don't forget to rate my assistance.
Feb 13, 2009 | Sanyo VPC-S500 Digital Camera
Instuctions for opteka 650-1300 lens for use on konica minolta
Try turning off the shutter lock.. In my Dynax 7D manual it tells you to turn off shutter lock when attaching to a telescope or microscope this is what this lens basicly is .The shutter lock is turned on and off in section three of the custon menu on my Dynax ,check your manual for your camera to find out where to turn on and off shutter lock, hope this helps
Jan 18, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Poor focusing konica Minolta Dimage Z6
I have the same problem and the lens won't retract in.
Sep 02, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Instruction manual Minolta zoom 130c camera
http://www.amazon.com/Konica-Minolta-Zoom-130c-Camera/dp/B0000C4JZV After opening this page look under product description. Click on "Product manual" and it will open up the manual for you for free.
Apr 16, 2008 | Konica Minolta Zoom 130C Date 35mm Point...
Konica U-Mini AF 35mm Point and Shoot Camera Logo
265 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Ekse
Lawrence Oravetz
Are you a Konica Camera Expert? Answer questions, earn points and help others
