Cd player tray on my pc will not open - Computers & Internet
    Sergeant:
  • 226 Answers
On most CD players and writers a small hole only big enough for a very small pointed object is located usually on the right side and slightly below the tray. Straighten out a paper clip and put that into the hole and press until you find some small resistence. Do not overpress but do press until you feel a small click. Generally the tray will open at that stage. Suggest you remove whatever object or media is located in the tray at the point and reboot the computer. Hopefully the tray will then operate on its own as it should but it is possibly that the drive mechanism for the tray is dead. Test before replacing the drive. The above procedure should only be done with power ' not applied ' to the unit since it may be possible to cause an electrical short on the drive using a metal paper clip.
Posted on Aug 21, 2008
Cant open my cd player on my acer pc
On most cd/dvd players there is a small hole below the tray on desktop players and on the tray on laptops. Take a paper clip and carefully push thru the hole. This should release the cd tray.
Jan 31, 2015 | Acer Computers & Internet
Replace cd player
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 16, 2013 | Samsung Computers & Internet
Cd-rom player does not open
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Dec 24, 2012 | Acer Aspire 9500 Notebook
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
HOW DO i GET CD TO EJECT? WHAT DO I HIT?
There is an eject button on the drive tray, when the notebook is powered up then press this button to open the tray.
If it still does not open then straighten a paper clip and insert it into the pin hole in the tray and push it in gently until the tray pop out, you can then pull the tray fully out to get at the CD.
Dec 10, 2010 | Dell Studio 15 Laptop
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
Cd tray will not open
This might not be the solution you're looking for, but aside from the obvious, "Then get a new CD player," :) if you have something in there that you need to get out, every computer CD player has a very tiny hole somewhere on the front. If you straighten out a paper clip you should be able to manually open the CD tray by sticking the paper clip in that tiny hole and giving it a little "push" until the tray pops out enough to where you can just pull it the rest of the way out with your hand and salvage the CD.
Either way, good luck!
Jan 12, 2010 | Dell Dimension 4700 PC Desktop
Nakamichi MB-2 CD Player tray sticks
It sounds like the belt that opens the try is getting bad and beginning to slip, a common problem on CD players like this. You should be able to find a replacement belt online.
Nov 12, 2008 | Audio Players & Recorders
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
CD tray got knocked off track
You can try to fix mechanics by takin apart cd, remove tray and try open/close operation WITHOUT tray. Leave it as OPEN, then try to place tray back in fully open position, but be careful, you have to pres OPEN and then unplug it from outlet to avoid electric shock risk. BE CAREFUL!!!
Sep 25, 2007 | Technics SL-MC6 CD Player
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
