Question about Imation Computers & Internet
Imation 4 gig flash drive. files not visible but thru properties shows there is data on the drive.
  • lutherdg Aug 21, 2008
    1. do you mean the clock at the bottom right hand corner of the screen?
    2. What icon is it I need to use un-mount the USB drive?
    3. P C Inspector: I have tried to download it from the link you posted. Not downloading. I get 'error on page' message.
    Yes. The recommended software appears to have recovered the file.
    Master:
  • 397 Answers
Heres another free file recovery application:
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
Do not remove your flash drive without unmounting it first, always use the little icon by the clock to remove your USB device, what you have now is typical of a flash drive that was just pulled out of the machine without unmounting the drive.
Posted on Aug 21, 2008
  • Richard Finch Aug 21, 2008
    The icon is the little arrow like looking thing pointing slightly downward to the left, near your clock, antivirus and whatever else you have running.
    I am sorry the link is not working for you, I have just tried it three or four times and it worked fine.
    Try:
    You may have to select your language.
    Genius:
  • 1,847 Answers
If the data id not important format the drive and then try.
I have 16 gb imation pendrive,in my computer manage it shows 16gb(but in g: drive in properties it shows 0kb ,wat is the problem i can open it but cant create a files or anything{please help me}
May it would be a problem related to your system hard drive, have you checked your hard drive? OR It looks like the problem is related to fat and ntfs file corruption i am not sure what the exact problem in front of you .You can try Recovery Fix for NTFS Data Recovery. I hope this will be the solution for your worries.
Thanks.
Oct 11, 2012 | Computers & Internet
I have formatted my pen drive (Imation 8 Gb) due to viruses, and Now i am having access only to public partition not the secured one. What to do sir? Please i need help!
when you formatted it did you format the imation lock a format will remove all data from a drive you might need to get it back to open the locked partition or use some other software
you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Try this freeware call smart Data Recovery
http://www.smartpctools.com/recovery/ind...
This is different from other recovery software because it not only recover lost file from harddrive and floppy like most do, but also recover from removable media like flash drive.
hope this helps
Jul 12, 2012 | Computers & Internet
Pen drive memory problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
the right click on your drive select properties you will see how much data you have and the ammount free space
if you need more help with this post a reply
hope this helps you
Jan 12, 2012 | Imation Electronics - Others
I have an 8gb imation that become 4mb free space why it happen?
click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
click start click on computer then right click on your usb drive select format
(note formatting will remove all data on your drive)
then right click on your imation drive select properties you will seea mmount of space used and ammount of free space
hope this helps you
Nov 11, 2011 | Imation Products - imation - Clip Flash...
I have 16Gb imation flash disk and i deleted the icon that allow me to enter the secure partition so i can not access this secured partition what can i do
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover deleted partition with data recovery software.I have succeed with Tenorshare. It can recover data after deeply scanning your flash drive to look for lost data.You can get it here: http://www.any-data-recovery.com/index.htm
Download it and scan your hard drive for free to check out whether the deleted partition can be recovered.After you recover your data,you can format it to check out whether it can be fixed.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
This article may help.How to Recover Deleted Partition in Windows by Yourself Easily!?
May 31, 2011 | Computers & Internet
Imation Pendrive
First of all you need to scan the Flash Drive using update antivirus. Can you format the drive somehow? if so do it. You can recover the data later using data recovery apps such a Recover My files. If this doesn't work then there might be a damage with the Storage Device.. Good luck..
Apr 20, 2010 | Computers & Internet
Imation USB not reading in My Computer
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Sep 05, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Drive info inaccessible
just simply go to property and here is disk cleanup option....just run it....may be problem is due to some file are larger that is into the hidden folder......
unhide folder option and then see .....
Mar 30, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
125 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
