Frigidaire window air conditioner making buzzing noise
I bought a new Frigidaire air unit in May 2007- a couple months later the compressor stopped working and had it replaced by an authorized repair person- the service was terrible and it took over a month to get fixed- anyway I am stuck with this unit and after a couple weeks it started making a very loud buzzing noise every 20 minutes or so- can hear it a couple houses down from us. The compressor is still under warranty but a service diagnostic call is around $100 which I have to pay cause we have passed the 1 year mark-do not know if its worth it since the unit cost $350 .
    Genius:
  • 2,920 Answers
I would invest in a new unit the cost to get this one repaired will add up and theres no guarantee they will fix the problem
Posted on Aug 21, 2008
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
My a/c unit was working fine for the last couple of months. Unit would turn on run compressor would shut off fan would shut off a few minutes later. However approx. 11/2 weeks ago I noticed that when the...
this appears to be a stuck relay or contactor . follow the wire back from the fan and locate the contactor or relay slp it and see it it comes lose. ?? this does not mean it will solve the problem as you will still have to repalce any part that is causing it.. Hope this helps let me know Jon
Jul 25, 2011 | Frigidaire FAH125N2T Air Conditioner
Compressor will not stay on no matter the temp. setting. After running a couple of minutes the unit emits a scraping or buzzing noise and compressor goes off.
Sounds like you lost one of your fans if air is circulating in the room its the condenser fan. Thats what blows across the condenser coil to the outside. It may just be a capacitor thats what helps the fan get started but usually if the fan is popping capacitors there is something wrong with the fan but at the same time capacitors do just go bad. hope this helps let me know.
Jul 23, 2011 | Frigidaire FAH126S2T Thru-Wall/Window Air...
I have a new lg window air conditioner that is buzzing loudly when the compressor turns on. as soon as the compressor shuts off it stops buzzing. the buzzing noise also sounds like a playing card attached...
sounds as though the contactor is not pulling in tightly. but it also spunds as though the fan or fans might be hitting some thing . check them out shut the unit down and spin the fans and see if you hear something. if not then it could well be a contator .. But as I think a bit more could be lose fan, or compressor is not setting on it isloator bushings .
Jul 18, 2011 | LG Heating & Cooling
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
Heating & Cooling Logo
315 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
