Question about ASUS P4S800-MX Motherboard
Motherboard NO Boot
PC been working fine, turned on recently and NO GO (just lights and fans come on). I took PC apart, discovered Harddrive has gone (appears to be internal motor). Replaced Harddrive. Computer still does boot up. When I hook the hard drive up Ribbon and Power, the harddrive no go, but when I remove ribbon, the harddrive - I can feel it turn / run. I tried replacing parts (power supply, ribbons, etc.), but still no boot (bios, etc.)
  • dktozer Aug 22, 2008
    Even with a harddrive in the PC, the computer should give some beeps when started, and also allow for me to go into the BIOS set up ??
  • ASUS Master
  • 3,051 Answers
Have you made sure that the new hard drive is set to the same settings that the old one was ie master or slave and that the ribbon is attached the same way
Posted on Aug 22, 2008
  • Michael Thomas
    Michael Thomas Aug 22, 2008
    can u tell mhat kind of a computer it is and also can u try this unplug the power cord from the pc and open the case and remove the power cables to the motherboard and then press the power key and hold it there for 10 seconds to discharge all of the esd and then plug the motherboard back in and plug in the computer to the power and reboot and hold down the del key and see if it wilol let upi into bios
I have a Dell Dimension 5150 which has recently been taken out of storage to use again. It hasn't been used for a minimum of 2 years. Before it being put away it worked fine. The motherboard light is...
This is one of 3 possible problems. Either your motherboard has gone bad, your power supply has gone bad, or the connections from the power supply to the motherboard are not secure.
Nov 20, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a gateway model # gm5088. I power on the computer and work fine, but the blue light doesnt work and the pc doesn't want to boot. What seems to be the problem?
sorry i could not understand u said it work fine but the pc doesnt want to boot. if its only the light issue then the connection of that light to the motherboard must be lossed or the bulb must have been fused
and if ur pc not booting then it ur power supply on *********** board problem
good day
May 29, 2010 | Gateway GM5088 PC Desktop
The pc does not boot - no beeps jsut no display - all the fans are working - tried a different harddrive and memory same thing
there are 4 condensors on the motherboard next to the northbridge/main processor heatsink that have exploded. buy a new mb. and replace the old 1 by the way you are going to need a new processor also. when the caps blew they took out the brains/processor. or buy a new pc. and specify an asus mb. either way you go...
Nov 07, 2009 | EliteGroup PM800M2 Motherboard
Hello, a friend recently brought me a Presario c700 asking me to fix it. When I inspected it, it has occured to me that the entire thing looks completely fine, inside and out, I've checked this thing with...
What I recommend is you remove everything you could possibly remove from the laptop (HDD, mems, cd rom, wifi cards, etc) just to check if it will turn off even when it's not booting or posting. Try turning it on with just the charger and WITHOUT the battery and see if it stays on. If it doesn't, then most likely the mobo itself is the problem.
Oct 06, 2009 | Compaq Presario C700T Notebook
Dell Inspiron 8100 Motherboard Problem?
if the processor fan is off or removed processor heat and its work for 1 or 2 second thats why change the fan and then try again
Oct 02, 2009 | Dell Computers & Internet
Lights on, no display, doesn't boot
had similar problem on sony vaio. when power depressed, i could hear the cd drive turn a bit, the hard drive light blink once, and that's it. power light would remain on, but nothing else. I took it apart and resoldered all the main chasis grounds on the motherboard and shorted/resetted the board battery(memory/clock) and put everything back together and started up fine. got lucky i guess.
Sep 24, 2009 | Gateway MX6447 Notebook
Sony Vaio laptop vgn-fs640-w problems
The motherboard controls the fan speed - and laptops often turn it off entirely when it is not needed. This sounds like a motherboard issue where an internal trace is broken and sometimes it makes contact, other times not. There's probably nothing you can do except replace the motherboard.
Jan 18, 2009 | Computers & Internet
My laptop says a disk red error occurred and will not boot up it goes in circles asking for restarts and says the same thing also iam getting this message as well PXE-E61 MEDIA TEST FAILURE CHECK...
"PXE-E61 MEDIA TEST FAILURE CHECK CABLE"
This means that the motherboard and harddrive are not communicating correctly, there is no data cable to connect the harddrive to the motherboard on a laptop the harddrive connecting plug is soldered directly to the the motherboard.
Either your harddrive is dying, or your motherboard has gone faulty. Laptop repairs are quite involved, if you are not familiar with taking laptops apart I would suggest you get profesional help with this problem.
If you want to have a go yourself I can point you in the direction of websites I use when doing laptop repairs.
Sep 10, 2008 | Computers & Internet
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
ASUS P4S800-MX Motherboard Logo
216 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
